CNY_Dave Posted March 31, 2020 Share Posted March 31, 2020 I wish they lived close, I love a good mystery. I *used* to live right near New Britain. Link to comment Share on other sites More sharing options...
sirtokesalot Posted April 18, 2020 Author Share Posted April 18, 2020 well i ordered a arm bushings and 2 days later the passenger caliper seized. ended up having to remove it to get home on 3 brakes. guess what happened after taking the caliper of ..... im not gonna make ya guess. the shake virtually disappeared. there is still a light shaking at highway speeds but the obnoxious shake is gone. im guessing the used caliper i put on was sticking lightly for a bit and then decided to stick on completely the other day. Link to comment Share on other sites More sharing options...
Crazyeights Posted April 19, 2020 Share Posted April 19, 2020 It probably warped the brake rotor as well. Link to comment Share on other sites More sharing options...
lmdew Posted April 19, 2020 Share Posted April 19, 2020 Glad you found it. Link to comment Share on other sites More sharing options...
sirtokesalot Posted April 19, 2020 Author Share Posted April 19, 2020 16 hours ago, Crazyeights said: It probably warped the brake rotor as well. interestingly i dont think it has. i put the old caliper back on that was leaking whent he brake pads got low. it has new pads on it now and that caliper doesent leak with new pads under it. it does not seem to shake when pressing the brakes so i may have gotten lucky with that. and yes i have ordered caliper rebuild kits so it wont stay like that for long and i should have the calipers rebuilt before the pads wear enough for it to start leaking. Link to comment Share on other sites More sharing options...
el_freddo Posted April 20, 2020 Share Posted April 20, 2020 Make sure you grease the slide pins too. Clean out their guide holes before reassembly. Usually crusty old grease can cause a sticky guide resulting in brake shudder - but usually only under braking conditions. Glad to see you’re on the path to remedy the issue! Cheers Bennie Link to comment Share on other sites More sharing options...
sirtokesalot Posted April 26, 2020 Author Share Posted April 26, 2020 getting closer. today i changed both rear a arm bushings and the passenger lower ball joint. the drivers side the bolt was going to snap and i dont have the drill bits for that now so i left it for now. the car now drives dead smooth from 0 up to around 65 or 70 and then it starts to develop a slight shake in the wheel from there on. could this just be from the last ball joint thats left or is it a sign theres more still wrong beyond that. Link to comment Share on other sites More sharing options...
