Trailcutr Posted March 29, 2020 Share Posted March 29, 2020 1998 legacy outback. Only one fan is working and the fuse keeps popping, then it gets hot. 305k on the car...might just be a worn out fan? Link to comment Share on other sites More sharing options...
Rampage Posted March 30, 2020 Share Posted March 30, 2020 I would suspect one or both of the fans. Once the motor brushes wear down and the copper wire it is attached to will contact the commutator and sparks fly. You won't see them because the motor is sealed. Unplug the fan that is not working and see if the fuse still blows. I would check the fan operation without running the engine to get it hot this way. Remove the panel under the steering column and look for two green connectors. Plug them together, but do not make them click (they are hard to separate). Turn the IGN Key to run (NO START) and watch the fans. This TEST MODE will operate relays, solenoids, fuel pump, A/C compressor clutch and then run both radiator fans on low speed then high speed then off, and repeat the cycle until you turn the key off. Let it run through several cycles. You will have the one fan unplugged, so only one fan should run low then high. If the fuse blows when it switches to high, then that fan is bad. If that fan cycles low and high, turn the key off and plug the other fan in and turn the key on and see when the fuse blows. Don't forget to unplug the test connectors. Personally, I would replace both fans. 305k is a lot of run time for those little fan motors. I use Dorman and they seem to hold up good. One fan is listed for cooling and the other fan is listed for A/C. If you end up getting two with the same shroud, just swap the new motor and fan to your old fan shroud. Let us know what happens. 2 Link to comment Share on other sites More sharing options...
lmdew Posted March 30, 2020 Share Posted March 30, 2020 The You Pull and Pay - Self Serve yards will have plenty of lower mileage fans for you. Link to comment Share on other sites More sharing options...
Trailcutr Posted March 30, 2020 Author Share Posted March 30, 2020 Thanks so much! I'll give the test a try. Link to comment Share on other sites More sharing options...
Grennick Posted April 1, 2020 Share Posted April 1, 2020 On 3/30/2020 at 11:51 AM, Rampage said: I would suspect one or both of the fans. Once the motor brushes wear down and the copper wire it is attached to will contact the commutator and sparks fly. You won't see them because the motor is sealed. Unplug the fan that is not working and see if the fuse still blows. I would check the fan operation without running the engine to get it hot this way. Remove the panel under the steering column and look for two green connectors. Plug them together, but do not make them click (they are hard to separate). Turn the IGN Key to run (NO START) and watch the fans. This TEST MODE will operate relays, solenoids, fuel pump, A/C compressor clutch and then run both radiator fans on low speed then high speed then off, and repeat the cycle until you turn the key off. Let it run through several cycles. You will have the one fan unplugged, so only one fan should run low then high. If the fuse blows when it switches to high, then that fan is bad. If that fan cycles low and high, turn the key off and plug the other fan in and turn the key on and see when the fuse blows. Don't forget to unplug the test connectors. Personally, I would replace both fans. 305k is a lot of run time for those little fan motors. I use Dorman and they seem to hold up good. One fan is listed for cooling and the other fan is listed for A/C. If you end up getting two with the same shroud, just swap the new motor and fan to your old fan shroud. Let us know what happens. Good info. My uncle got this new Outback project with intermittent fan issue and blown the fuse twice in a month. I'll just finish installing the brake pad and continental tires on the current Wrangler project and we'll start working on the Outback. He said the fans are still working but it might better to just replace them. Link to comment Share on other sites More sharing options...
Rampage Posted April 1, 2020 Share Posted April 1, 2020 If it is the 20 AMP fuse in the box under the hood that blows then it is the Main fan causing it to blow. If it is the 20 AMP fuse 13 under the dash then it is the Sub fan causing it to blow. As you said, replace both fans is best. Lower mileage used ones or new. Link to comment Share on other sites More sharing options...
