'90 Loyale no fuel, no spark
My son and I recently purchased a 1990 Loyale for his first vehicle. Low miles, clean steel.
It was running great for the first couple weeks then it wouldn't start at all.
The starter is cranking but there's no fuel and no spark.
We jumped the fuel pump and that seems to be working fine.
Replaced the crankshaft position sensor which was in the distributor with no luck.
Finally, we ordered a used ECM which claimed to work for about 90$ on eBay.
Still no luck!
Maybe we have two faulty ECMs?
Or maybe we are missing something.
Any leads or tips will be very appreciated!
If you have an ecm aka ecu, is it for some sort of fuel control of a carby? SPFi then? MPFi ??
My experience only lies with EA82T MPFi
They use a diagnostic LED built into the ECU which often tells the problem, sometimes nothing related to problem
You need to find how yours works
It may be flashing a code or just indicate a healthy O2 sensor?? Or you may need to do the step byy step to get it to spit some codes
I like Bennie's suggestion if timing belts, easiest check is dust cap off to see if rotor spins on cranking
  • Thanks 1
Thank you both for your input!
It's a throttle-body injection system.
ECU 22611AA394
is the brain.
the timing belts are uncovered but not broken.
I've checked the fuses and relays.
Our next move is to go through the wiring thoroughly looking for shorts or a burnt out link
Edited by LoyalLion
