rear drums to disks
if you can t find 2wd discs, find 4wd discs and take the whole trailing arm. you will have the axle stub, parrs invested for future conversion!
4wd trailing arms alone on a 2wd will
RAISE THE BACK END UP A BIT. easy "lift" for the saggy bottom soob
and ea82 rear trailing arms will fit in an ea81 with a little grinding and reaming on one bolt hole
