Jacob 2002 Posted May 1, 2020 Share Posted May 1, 2020 (edited) Ok guys so i have a 91 loyale that has no spark. I have checked coil,fuses,relay, and made sure the bracket was grounded. i have no spark at the coil so i know its not the wires of distributer. i have power across the coil terminals,but only 8.55 volts. does anybody have any suggestions on what i should do to fix it? its a 1.8 spfi front wheel drive(if that makes a difference?) any help is appreciated. Edited May 1, 2020 by Jacob 2002 Quote Link to comment Share on other sites More sharing options...
Dee2 Posted May 1, 2020 Share Posted May 1, 2020 What is voltage at the battery ? Have you checked the fusible links for corrosion ? Quote Link to comment Share on other sites More sharing options...
Jacob 2002 Posted May 1, 2020 Author Share Posted May 1, 2020 the battery voltage is 12.1 (a little low now that you mention it) and i replaced all the links with 14g wire to make sure they werent the problem. Quote Link to comment Share on other sites More sharing options...
DaveT Posted May 1, 2020 Share Posted May 1, 2020 12.1 is very low, almost totally discharged. Links? If you mean the fusible links, get proper ones, that is a fire hazard. 2 Quote Link to comment Share on other sites More sharing options...
Jacob 2002 Posted May 1, 2020 Author Share Posted May 1, 2020 yea i meant the fusible links, and yes i know they are a hazzard, it was just a quick way to make sure i had connection i didnt realize my battery had got that low i will charge it and see if that fixes it. Quote Link to comment Share on other sites More sharing options...
Rampage Posted May 1, 2020 Share Posted May 1, 2020 2 hours ago, Jacob 2002 said: i have power across the coil terminals,but only 8.55 volts. You should check the coil + and - to ground with the volt meter. If you have a test light, hook the clip to ground and hold the probe tip on the coil negative and crank the engine. Does the light flicker? 1 Quote Link to comment Share on other sites More sharing options...
Jacob 2002 Posted May 2, 2020 Author Share Posted May 2, 2020 uh I dont have a test light but i have a multi meter,I also just noticed that when i leave the switch on the coil gets hot is that normal or do i have a short? Quote Link to comment Share on other sites More sharing options...
Dee2 Posted May 2, 2020 Share Posted May 2, 2020 44 minutes ago, Jacob 2002 said: uh I dont have a test light but i have a multi meter,I also just noticed that when i leave the switch on the coil gets hot is that normal or do i have a short? It would be worth taking it in and having it tested..... Quote Link to comment Share on other sites More sharing options...
Rampage Posted May 2, 2020 Share Posted May 2, 2020 58 minutes ago, Jacob 2002 said: when i leave the switch on the coil gets hot Not normal. Electronic ignition uses pulses from the distributer or SPFI Module to fire the coil. If the engine is not turning, no pulses, no current through the coil, no heat. There should be battery voltage on the + and - of the coil. The coil bracket should have a power transistor (ignitor) mounted on it? If so, it is probably shorted. You can unplug it and test it with an OHM Meter. Put the meter on the diode symbol if it has one, otherwise use the lowest OHM setting. The transistor has three terminals one is ground. Put the black probe on ground. You might see 75 on one pin, If you find a very low reading on the other terminal, it is toast. If you get no short on the transistor, the only other thing that could turn the transistor on would be a voltage leak that should not be there from the SPFI module. The diagram is for an 89. The transistor works like a switch. An input pulse turns it on and connects the coil negative to ground and when the pulse turns off, the coil will produce a spark. 3 Quote Link to comment Share on other sites More sharing options...
DaveT Posted May 2, 2020 Share Posted May 2, 2020 Regarding the links, yes, ok for a test, I wouldn't leave them that way. The battery, yes, charge it, since it's not good for lead acid batteries to sit discharged. But the battery charge is not the cause of the bigger problem. Quote Link to comment Share on other sites More sharing options...
