JFDI Posted May 13, 2020 Share Posted May 13, 2020 check engine light on on my loyale 1992 AT sedan. Unable to locate the diagnostic port/plug. It's pre ODB2 obvioulsy, not sure where to start. thanks for suggestions! Link to comment Share on other sites More sharing options...
Dee2 Posted May 14, 2020 Share Posted May 14, 2020 https://www.2carpros.com/articles/subaru-diagnostic-trouble-code-definitions-1987-1994-obd1-with-code-gathering Link to comment Share on other sites More sharing options...
DaveT Posted May 14, 2020 Share Posted May 14, 2020 Remove the kick panel from under the steering column. Bolted to the column, there is a plain metal box. there is a hole pointing toward the driver. peeking into the hole, you can see a red LED. [when it is blinking] Start the engine. Look at the LED. Long blinks are the tens place digit. Short blinks are the one's place digit. All numbers are 2 digits. Codes are listed in a sequence, then repeated. There may be only one, like 34, or a few, 34, 31, 35. Look up the code numbers, and or post them here. Link to comment Share on other sites More sharing options...
