maiajr Posted May 28, 2020 Share Posted May 28, 2020 (edited) I recently got a 91 loyale 3at with 110k on it and it had a bad modulator on it. After I fixed that the governor drive gear failed. Any one know where I might find one. Edited May 28, 2020 by maiajr Link to comment Share on other sites More sharing options...
silverhelme Posted May 28, 2020 Share Posted May 28, 2020 About the only place you will find one is a junk yard or if someone here may be junking out a 3at. If you find one dig in the archives for an article about how to make them work right. I may have one but due to medical problems I can't get to it at the moment. If you get it fixed be sure and adjust the 2-3 band also. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 28, 2020 Share Posted May 28, 2020 You called and left a message at my shop - sorry I was on the other line. I'll just answer here though. Unfortunately I don't have any 3AT parts. You might call call John's Subaru in Gaston, OR. He's a Subaru specific junk yard. Also you could swap it to a manual transmission. Probably your best bet. Those 3AT's were $hit from the start and you can't get any parts for them anymore. GD Link to comment Share on other sites More sharing options...
maiajr Posted May 29, 2020 Author Share Posted May 29, 2020 3 hours ago, GeneralDisorder said: You called and left a message at my shop - sorry I was on the other line. I'll just answer here though. Unfortunately I don't have any 3AT parts. You might call call John's Subaru in Gaston, OR. He's a Subaru specific junk yard. Also you could swap it to a manual transmission. Probably your best bet. Those 3AT's were $hit from the start and you can't get any parts for them anymore. GD Hi Thanks for answering. I agree with the manual trans idea. Looking for a brake/clutch pedal box but not any luck so far. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 29, 2020 Share Posted May 29, 2020 Pedal assembly should be easy - call John's in Gaston. I'm quite sure he has all that stuff. You will also need the clutch/flywheel, shift linkage, driveline, and matching rear diff if it's not the same. GD Link to comment Share on other sites More sharing options...
