Skubaskott Posted June 4, 2020 Share Posted June 4, 2020 I have my harness mostly stripped. But there is a wire that goes seemingly no where but is great shielded. Any idea what it is it runs from the smj to the harness that is attached to the engine. Smj pins: L6, L5, L4 Link to comment Share on other sites More sharing options...
el_freddo Posted June 4, 2020 Share Posted June 4, 2020 You need to reference the pins from the ECU side of things. Those are the pins I only refer to. Some wire tracing may be needed. And that junction can be cut out, it’s not needed (unless the USDM loom is vastly different to our AUDM looms). Cheers Bennie Link to comment Share on other sites More sharing options...
Skubaskott Posted June 5, 2020 Author Share Posted June 5, 2020 On 6/4/2020 at 3:31 AM, el_freddo said: You need to reference the pins from the ECU side of things. Those are the pins I only refer to. Some wire tracing may be needed. And that junction can be cut out, it’s not needed (unless the USDM loom is vastly different to our AUDM looms). Cheers Bennie Expand There is no connection between this shielded wire and the ecu. Even though the wire has a connector that connects to the harness running under the intake manifold Link to comment Share on other sites More sharing options...
el_freddo Posted June 5, 2020 Share Posted June 5, 2020 What colour and trace colour are those wires? They could be temp gauge or oil warning lights. Dunno why it would be shielded though. Cheers Bennie Link to comment Share on other sites More sharing options...
