AWD Classic Beetle
SamJM
This is where my build currently sits, figured I'd share it. It's a 1967 Beetle dropped on a 1998 Subaru Impreza NA 2.2 chassis. I had the shorten the pan about 5 inches and the suspension is a bit wide in the rear. There were a handful of routes I could have take th avoid that like cutting the body in half or lowering the shock towers and putting shorter shocks in, but I want the beetle to have as many off the shelf parts as possible so if something breaks I can easily find it.
The front end is not staying like that, I'm going with a full fiberglass front but I'm not going to touch all that until I have the back sorted.
The build is also getting uploaded on youtube if you want to follow along:
Edited by SamJM
  • 1 year later...
Just watched the three videos and was hoping for a few more updates.
Also a bit of a shame he didn’t use the Gen3 legacy multi link rear end, no need to cut into the upper bodywork to clear the strut towers.
I’m also a bit jealous about what you guys can “get away” with over there. Here in Oz this thing would need a massive amount of engineering to be deemed roadworthy, and depending on which state you’re in also dictates what you need to do exactly!
Cheers
Bennie
