5000fingers Posted June 23, 2020 Share Posted June 23, 2020 During COVID I haven't been paying enough attention to my Subie I guess. When I started up today after changing the sway bar end links, the oil light didn't turn off. So I immediately shut down and found out that it was 2 quarts low. That's bad, but not bad enough to trigger an oil light until just now. So anyway, I immediately topped it all the way up to the full line on the dipstick, and now the oil light won't go off. What is likely the culprit, and how should I diagnose it? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 23, 2020 Share Posted June 23, 2020 What model and year are we working on? GD Quote Link to comment Share on other sites More sharing options...
rverdoold Posted June 23, 2020 Share Posted June 23, 2020 The oil pressure sender on top of the block (behind alternator) can go wrong. They faul and eventually fail, but usually the other way around, not showing a light at all. By shorting the connector to the block the light should go on. It could be that there is a short in the sender. Unplug the single wire cable from the sender, and see if the light goes out. Then short it on the block somewhere else and see if the light goes on again. This is a cheap part to start with to change. Quote Link to comment Share on other sites More sharing options...
5000fingers Posted June 23, 2020 Author Share Posted June 23, 2020 11 hours ago, GeneralDisorder said: What model and year are we working on? GD It's a 2011 Outback, 4 cyl. Quote Link to comment Share on other sites More sharing options...
5000fingers Posted June 23, 2020 Author Share Posted June 23, 2020 OK, it looks like that was the "oil level warning light," not the oil pressure warning light. Good grief, what were they thinking? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 23, 2020 Share Posted June 23, 2020 They were thinking they needed to alert you that the oil level was 2 quarts low. Which they did. Mission accomplished. GD 3 3 Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 25, 2020 Share Posted June 25, 2020 On 6/24/2020 at 12:47 AM, 5000fingers said: Good grief, what were they thinking? That their engine is going to consume enough oil between changes to warrant a low level oil warning light? Cheers Bennie Quote Link to comment Share on other sites More sharing options...
