does anyone know a company that makes clear housing headlights for the 96 legacy? I h ave seen a few on other legacys my year but everyone I ask says they are stock. Im looking to get m ore light output, i already have upgraded led bulbs
I doubt they purchased them like that.
They were probably cleared at home.
Do search on how to clear headlights.
You basically have to put unit in a warm oven, separate the halves, remove  orange parts and reseal.
Best to start on an extra set, so if you mess it up, you'll still have a working units.
O.
you probably just need to do a good clean & polish.. if the headlight housing looks yellowed or hazy, that is exactly what you need to do
Maguire's (and others) sells a kit that has two grades of sanding pads with a holder, polish, an applicator pad for the drill, and a sealer all in one box.
the trick is to make sure you wet sand out ALL of the yellowing/hazing before going to the polish.
It will not last forever - 6mos to a year depending on conditions, but it does do a good job of cleaning things up and improving light output
Edited by heartless
