Leebo Posted June 26, 2020 Share Posted June 26, 2020 86 GL10 Fan hit the radior I believe while I was accelerating. I came out to a pool of coolant under my bumper the next morning. Could my motor have shifted forward while under load because something is worn? Any input would be appreciated. also suggestions on aftermarket radiators or should i try to get an oem if possible? Thanks!! Lee Link to comment Share on other sites More sharing options...
el_freddo Posted June 26, 2020 Share Posted June 26, 2020 Check your pitch stopper rod and ensure it’s still bolted in firmly. Also check for broken engine or gearbox mounts. Cheers Bennie 2 Link to comment Share on other sites More sharing options...
Step-a-toe Posted June 26, 2020 Share Posted June 26, 2020 Yeah, things flex normally a bit, more as mounts age or crack n break. This is the clutch fan off water pump? I ditched mine and fitted twin electric fans and being EA82 in EA81 body and radiator think things are closer, I had a pulley just buzz my fan wiring insulation until I better retained wires Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 28, 2020 Share Posted June 28, 2020 drive thru very high water? it can flex blades forward.... Link to comment Share on other sites More sharing options...
ferp420 Posted July 2, 2020 Share Posted July 2, 2020 loose radiator mounts maybe i would guese lower mounts Link to comment Share on other sites More sharing options...
