beachbum Posted July 8, 2004 Share Posted July 8, 2004 not mine just a heads up if somebody can use says its a 1 bbl for brat http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33550&item=7909634268&rd=1 Link to comment Share on other sites More sharing options...
edrach Posted July 8, 2004 Share Posted July 8, 2004 beachbum said: not mine just a heads up if somebody can use says its a 1 bbl for brat http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33550&item=7909634268&rd=1 It is a weber, but I think the 2 barrel hitachi original is better. This one doesn't have the "poop" of the two barrel weber. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 8, 2004 Share Posted July 8, 2004 It also requires a different manifold, and some of the carter/weber's were feedback...... I don't know enough to say if this one was or wasn't because as Ed pointed out - they suck. Really tough to find parts for too. GD Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted July 8, 2004 Share Posted July 8, 2004 Every C/W that I've run has given me nothing but good, I swear by em. Had tonnes of probs with the Hitachi's. Found that all the C/W's, feedback or not will run the same with or without a computer. Link to comment Share on other sites More sharing options...
Sweet82 Posted July 8, 2004 Share Posted July 8, 2004 Ok, I'll ask............ What's a feed back carb? Glenn 82 SubaruHummer with a Carter-Weber 01 Forester Link to comment Share on other sites More sharing options...
Guest taprackready Posted July 8, 2004 Share Posted July 8, 2004 Sweet82 said: Ok, I'll ask............ What's a feed back carb? Glenn 82 SubaruHummer with a Carter-Weber 01 Forester Well its the next best thing prior to fuel injection. Basically the 02 sensor in conjuction with computer and temp sensors electronically tell the carb how rich/lean to make the mixture for any given RPM range. Normally on non-feedback carbs they are set and never change unless you change the jetting or idle mixture manually. The feedback carb has the advantage of "feedback" from temp and exhaust gasses to tell it if the mixture is just right. Bill Link to comment Share on other sites More sharing options...
beachbum Posted July 8, 2004 Author Share Posted July 8, 2004 thnx sweet i was going to have to ask if u didnt:-\ Link to comment Share on other sites More sharing options...
