dmjamrock Posted July 1, 2020 Share Posted July 1, 2020 Hi all, I have a 2103 Subaru Legacy DTI. The car is wonderful but all 4 electric windows have now stopped working. It started with the driver's window and the wing mirror not closing. Then the other 3 worked on and off till it became off! I can't believe all 4 motors or switches have gone. Has anyone come across this. I live in jamaica so parts are expensive and not that readily available. Garages here will charge a fortune and you will still have the problem! Look forward to any suggestions. Link to comment Share on other sites More sharing options...
lmdew Posted July 2, 2020 Share Posted July 2, 2020 I fixed a 2011 for a friend. Her cable on the window motor had a loose strand that bound up the window. Make sure you inhibit button for the passenger windows is not on. Other than that, start checking for power. Link to comment Share on other sites More sharing options...
dmjamrock Posted July 2, 2020 Author Share Posted July 2, 2020 19 hours ago, lmdew said: I fixed a 2011 for a friend. Her cable on the window motor had a loose strand that bound up the window. Make sure you inhibit button for the passenger windows is not on. Other than that, start checking for power. Hi thanks, yep I checked the button, I cant believe thought all 4 motors would go like that. At the weekend might take the driver's door cover off and have a look at the switches. Link to comment Share on other sites More sharing options...
somick Posted July 3, 2020 Share Posted July 3, 2020 You may actually watch all three. It may answer your question. Good luck, Sam 1 Link to comment Share on other sites More sharing options...
dmjamrock Posted July 3, 2020 Author Share Posted July 3, 2020 1 hour ago, somick said: You may actually watch all three. It may answer your question. Good luck, Sam Hi great thanks, will have a look today. Fingers crossed. Link to comment Share on other sites More sharing options...
