Ionstorm66 Posted July 20, 2020 Share Posted July 20, 2020 I've been trying to find a good replacement for the shift bushing and springs. My shifter has gotten so bad you can't even tell it's in gear anymore. I have to shift it up and down to check! Link to comment Share on other sites More sharing options...
Subarule Posted July 20, 2020 Share Posted July 20, 2020 Maybe a new flywheel is in your future? Link to comment Share on other sites More sharing options...
573417h Posted July 26, 2020 Share Posted July 26, 2020 On 7/21/2020 at 6:17 AM, Subarule said: Maybe a new flywheel is in your future? Is there something to this statement? Link to comment Share on other sites More sharing options...
moosens Posted July 26, 2020 Share Posted July 26, 2020 (edited) Let’s read the theory behind this one. As for shifter bushings , I sold what might be my only set to someone not too long ago on eBay. I can’t recall who at the moment but discussion was that they should be copied. FYI you folks should be aware that there is also a seat bushing at the end of the lever where it meets the transmission. And also the seal should be replaced. This info is for the single range on demand 4WD Good luck with it. Edited July 26, 2020 by moosens Link to comment Share on other sites More sharing options...
Step-a-toe Posted July 26, 2020 Share Posted July 26, 2020 Assuming OP is talking EA81 4 speed????? Link to comment Share on other sites More sharing options...
el_freddo Posted July 26, 2020 Share Posted July 26, 2020 1 hour ago, moosens said: This info is for the single range on demand 4WD Which will be relevant to the dual range too. @Ionstorm66 - are you talking about the bushes in the shifter knuckle or the bush at the base of the lever/stick? 3 hours ago, 573417h said: Is there something to this statement? Who knows? Maybe @Subarule could enlighten us..? 6 minutes ago, Step-a-toe said: Assuming OP is talking EA81 4 speed????? Good point Steptoe, in which case I’d suggest the slot and bolt trick. Worked nice on mine. I recommend a metal lock nut. Nylon just doesn’t cut it with potential oil etc. Cheers Bennie Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 26, 2020 Share Posted July 26, 2020 Get our your lathe and some bushing bronze. Only way any of that is going to get fixed at this point. All those parts are NLA. GD 2 Link to comment Share on other sites More sharing options...
Subarule Posted July 26, 2020 Share Posted July 26, 2020 11 hours ago, 573417h said: Is there something to this statement? Sorry, replied to the wrong post. 1 Link to comment Share on other sites More sharing options...
carfreak85 Posted July 27, 2020 Share Posted July 27, 2020 Delrin or urethane rod stock both work well for shifter bushings. Link to comment Share on other sites More sharing options...
Ionstorm66 Posted July 27, 2020 Author Share Posted July 27, 2020 If you had the dimensions it would be nothing to get a custom seal shop to make bushings, Ive had them made that way before. I guess ill pull it apart and check them all. Its also a e82 5 speed. The odd thing is up and down is 100% clapped, but left/right only left is clapped. Going into 5th and reverse actually has resistance. Link to comment Share on other sites More sharing options...
