Misfire with no check engine codes on 2006 H6?
How do you diagnose a light misfire with no check engine light?
2006 Tribeca 210,000 miles, new plugs and air filter. Constant light misfire.
Runs and drives fine as a daily driver, seems to under perform a little which isn't ideal as it's my main tow vehicle.
might be a wire(s) on its way out??
those are the coil on plug type, correct?
but yeah, kinda hard to know which with no CEL giving an indication of which cylinder is the problem
have you checked for any arcing in the dark?
Expand
COPs, so no wires.  haven’t checked for arcing. Maybe I should pull COPs and checks for oil leaks but there’s not a drop of oil anywhere and no CEL so I doubt it’s that.
Im wondering if I can pull data, freeze frame, if that’s easy enough to do in a situation like this. Look at throttle, O2, etc.
Edited by idosubaru
  • Like 2
