Christielee Posted August 4, 2020 Share Posted August 4, 2020 Are the struts compatible for a 1996legacy wagon and a 2004 legacy gt? Link to comment Share on other sites More sharing options...
ocei77 Posted August 5, 2020 Share Posted August 5, 2020 (edited) You can check compatibility by checking sites like RockAuto or an online dealer and see if they use the same numbers. O. Edited August 5, 2020 by ocei77 correction Link to comment Share on other sites More sharing options...
lmdew Posted August 5, 2020 Share Posted August 5, 2020 Fronts a slightly different but should work. Rears are totally different. Link to comment Share on other sites More sharing options...
idosubaru Posted August 5, 2020 Share Posted August 5, 2020 Front can struts interchange. Rear is totally different and can not. Many Outback wheels and tires won’t fit under front legacy struts, they hit the lower spring perch. outback front struts on a legacy lifts the car 2” and works fine. Front legacy struts on an outback you need to make sure the wheels tires aren’t too big to clear the lower spring perch of the legacy. If you run legacy wheel and tire size then you’re fine to install legacy front struts on outbacks. Link to comment Share on other sites More sharing options...
