Step-a-toe Posted August 15, 2020 Share Posted August 15, 2020 The worst one I have seen to date I can see wear from the cam drive The other end of its drive shaft has been scratched up wearing into the housing and the other rotating parts much the same The O rings, evolved into flat and square cross sections as expected. I wonder if I should still save it for someone in desperate need to keep a junker running. The housings are not broken at least. Apply within Link to comment Share on other sites More sharing options...
el_freddo Posted August 15, 2020 Share Posted August 15, 2020 Awww... no pics?? Bennie Link to comment Share on other sites More sharing options...
Step-a-toe Posted August 16, 2020 Author Share Posted August 16, 2020 Need to set up the studio for pics Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 16, 2020 Share Posted August 16, 2020 Send it to the smelter. If someone really wanted to, they could install an external pump. GD 1 Link to comment Share on other sites More sharing options...
Step-a-toe Posted August 16, 2020 Author Share Posted August 16, 2020 If desperate, I reckon a machinist would trim a little off the pump end, fit a sintered bronze bushing in pump body .. Link to comment Share on other sites More sharing options...
Step-a-toe Posted August 16, 2020 Author Share Posted August 16, 2020 5 hours ago, GeneralDisorder said: Send it to the smelter. If someone really wanted to, they could install an external pump. GD Like a dry sump rally set up? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 16, 2020 Share Posted August 16, 2020 Exactly Link to comment Share on other sites More sharing options...
