glsubby Posted August 28, 2020 Share Posted August 28, 2020 Hello all, 2019 Toyota GT86 TRD Edition I know this sounds dumb, "just replace the battery", but my battery tests fine at NAPA every time as well as the alternator. It'll start up fine in the morning, drive fine, I go to the store, get back in and it either has a super hard and slow start or it is dead. I've even driven it four a few hours and then parked, same result. If the charging system is fine then possibly something is pulling excessive amperage? Jump the battery, perfect 14 volts w/perfect start. Has anyone had this issue? I find it hard to believe the factory alarm system would drain it while locked/parked. Also, they're absolutely no aftermarket parts on my 86. The battery is Toyota factory, about two years old. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 29, 2020 Share Posted August 29, 2020 you can use a multimeter to monitor 'dark current' while pulling fuse to pin-down the offending system. any work,wrecks, mods to the car before this began? (electronics plugged in, new head unit, dash cam or ???) Link to comment Share on other sites More sharing options...
glsubby Posted September 1, 2020 Author Share Posted September 1, 2020 No wrecks (I had a cosmetic bumper tap but the engines so far back it didn’t impact). No mods or aftermarket anywhere. I did jump my GL once or twice with it. Maybe I didn’t let it run after for a while and this bogged the battery down? Link to comment Share on other sites More sharing options...
1990carenthu Posted August 4, 2021 Share Posted August 4, 2021 On 9/1/2020 at 6:19 PM, glsubby said: No wrecks (I had a cosmetic bumper tap but the engines so far back it didn’t impact). No mods or aftermarket anywhere. I did jump my GL once or twice with it. Maybe I didn’t let it run after for a while and this bogged the battery down? Expand Have you managed to solve this issue? It is important to at least start the car from time to time to avoid such issues. Link to comment Share on other sites More sharing options...
8string Posted December 22, 2021 Share Posted December 22, 2021 This seems to be an ongoing issue with certain later model Suburu's. My 16 outback routinely has the battery die. I simply carry a portable jumper in the car and jump it when it does. However, I think that the battery does not have enough cranking amps to properly address starting it when you drive around town on short trips frequently and use the heater, seat heater, radio, monitor and the rest. Even the Suburu service guys, who actually are nice folks up my way, admitted I should get a different battery with more cranking amps as the issue is " a common one". I'm planning on getting a gel battery in the near future. Maybe even tomorrow. It wouldn't start today after being driven just two days ago. Weather is cold here though. Link to comment Share on other sites More sharing options...
