Geluso Posted September 2, 2020 Share Posted September 2, 2020 Anyone else have trouble with your clutch cables? I think my engine is overheating and causing this to snap right off the fork. It has happened to me twice in the past three weeks. Symptoms: * Car has a high idle. the throttle cable is gummed up on the carb so it doesn't always return to neutral position immdiately. * A friend has suggested their might be a vacuum leak * The cable snapped when I'm starting the car. I press the clutch just a bit harder to get it going and the last strand snaps. Sound familiar to anyone? Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 3, 2020 Share Posted September 3, 2020 Are the cables OEM, or aftermarket? I've seen many comments that the aftermarket cables are not very good. The big nut looks wrong. There should be a half sphere face in contact with the fork - on the ones I have seen anyway. What is the true color of the area right at the break? It looks discolored. IT seems very odd to me that it broke so cleanly also. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 3, 2020 Share Posted September 3, 2020 Either you aren't using OEM cables, or it's routed improperly. You MUST get the cable from Subaru. And it MUST be routed under the steering column. Also the fork pivot, etc needs to be greased and working smoothly. GD 2 Quote Link to comment Share on other sites More sharing options...
Mr. Carb Posted September 4, 2020 Share Posted September 4, 2020 I had a one year old cable snap on the pedal end. Last time I checked you can't get OEM new cables anymore for the ea81, is that incorrect? Quote Link to comment Share on other sites More sharing options...
Step-a-toe Posted September 4, 2020 Share Posted September 4, 2020 Yeah, such a clean break, looks like vandals. Has the clutch and it's declutch bits been inspected, you know, engine and box separated? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 4, 2020 Share Posted September 4, 2020 13 hours ago, Mr. Carb said: I had a one year old cable snap on the pedal end. Last time I checked you can't get OEM new cables anymore for the ea81, is that incorrect? Last time I checked I was able to get one no problem. Probably been a year or more though. GD Quote Link to comment Share on other sites More sharing options...
Mr. Carb Posted September 4, 2020 Share Posted September 4, 2020 I'll have to check with my favorite parts guy and find out. :-) Quote Link to comment Share on other sites More sharing options...
Geluso Posted September 5, 2020 Author Share Posted September 5, 2020 Thanks for the info. I've been buying through O'Reilly's getting cables that come in Pioneer boxes, part number CA-891. Doesn't sound like OEM. I'll double check the routing. I'm sure I've got it under the steering column at least. The discoloration looks like the cable is being affected by heat to me. The cut looks clean enough that vandals did it, but I distinctly felt it snap pushing with my own foot. Anyone have tips where to get OEM cables? I'll start shopping around. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 5, 2020 Share Posted September 5, 2020 You buy them from the dealer parts department. GD Quote Link to comment Share on other sites More sharing options...
Mr. Carb Posted September 12, 2020 Share Posted September 12, 2020 Update: There was three left in the entire county when I talked to the parts department. I picked up two of them so I have a spare in case one breaks later. I'll try to get manufacture information to see who makes them for aftermarket purposes. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 12, 2020 Share Posted September 12, 2020 They don't have any manufacturing information on them. They are made in Japan and are likely out of production. You're not going to be able to source them from the manufacturer - that's wishful thinking. GD Quote Link to comment Share on other sites More sharing options...
Step-a-toe Posted September 12, 2020 Share Posted September 12, 2020 At least he has a sample to take to a cable maker if they exist any more 1 Quote Link to comment Share on other sites More sharing options...
moosens Posted September 12, 2020 Share Posted September 12, 2020 Maybe as classic cars move forward someone will be selling some serious DIY cable making kits like motorcycle owners have had to do. Maybe they exist already for cars and trucks ? So my clutch cables just went up in price , cool. Routing is key. Making sure your pedal box isn’t cracked is another. Older 70’s first gen you want that support spring hanging it too. It all helps and all belongs there and in their respective places. Quote Link to comment Share on other sites More sharing options...
franbev Posted September 14, 2020 Share Posted September 14, 2020 What's the Subaru OEM part number for the clutch cable on a 1985 Brat? Quote Link to comment Share on other sites More sharing options...
