SightlineSubi Posted September 19, 2020 Share Posted September 19, 2020 (edited) Hello every! So I've started moding up my 1982 GL wagon. It' has a lifted body and suspeion and I'm running kuhmo 27.5 tires. I'm almost finished doing an SPFI conversion and an EA82 swap. Got the engine and harness/ecu from a 1988 GL sedan 4wd. I'm building an EA 81 engine on my shop bench too and may swap back to the original after a while and once I'm finished building the 81. I may.......uh hum.....keep the 82 even until it quits. Either way I'll have the SPFI system on whatever I run. Ive already done the distributor conversion fir the 81 to use the SPFI manifold and SPFi on it. It has a Weber carb now. The new FI fuel pump comes in tomorrow so I should be firing her up. Have a bit of wiring and alot of organizing of the new harness to do first tho. I've been busy fabricating a winch bar and installing a new winch on the front past couple days. Here's a few pics of how that turned out. I found some 1965 mustang sway bars (2) Edited January 5, 2021 by SightlineSubi Link to comment Share on other sites More sharing options...
SightlineSubi Posted September 19, 2020 Author Share Posted September 19, 2020 Link to comment Share on other sites More sharing options...
SightlineSubi Posted September 19, 2020 Author Share Posted September 19, 2020 On 9/19/2020 at 9:18 AM, SightlineSubi said: Expand The I wish it were in a barn find....... Link to comment Share on other sites More sharing options...
SightlineSubi Posted September 19, 2020 Author Share Posted September 19, 2020 It cleaned up well Link to comment Share on other sites More sharing options...
SightlineSubi Posted September 19, 2020 Author Share Posted September 19, 2020 It's cleaned up well Link to comment Share on other sites More sharing options...
SightlineSubi Posted September 19, 2020 Author Share Posted September 19, 2020 Fits like a glove. Cheapo unit from Amazon. Less than $100. Works pretty well it seems too. 1 Link to comment Share on other sites More sharing options...
