Step-a-toe Posted October 2, 2020 Share Posted October 2, 2020 If you jack front end up, place stands or blocks under the lower control arms so you can turn full lock to lock by hand to see if you can pick something binding 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 2, 2020 Share Posted October 2, 2020 does it feel like pulling, or a failure to return to center or ??? is there any whining from the PS pump? Link to comment Share on other sites More sharing options...
Step-a-toe Posted October 2, 2020 Share Posted October 2, 2020 2 minutes ago, 1 Lucky Texan said: does it feel like pulling, or a failure to return to center or ??? is there any whining from the PS pump? Now that is getting down to the Nitty gritty of diagnosis ! Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 2, 2020 Share Posted October 2, 2020 14 minutes ago, Step-a-toe said: Now that is getting down to the Nitty gritty of diagnosis ! lol, just asking questions - I have no idea why......... Link to comment Share on other sites More sharing options...
IfjdmaintAwD Posted October 7, 2020 Share Posted October 7, 2020 On 9/30/2020 at 5:29 PM, Ionstorm66 said: It isn't a brake, because the wheels rotate freely when off the ground. Also info is on my profile. Its a 92. Took forever to figure out why I commented on this. Was the latter of the post about year/model. My bad! Link to comment Share on other sites More sharing options...
djellum Posted October 7, 2020 Share Posted October 7, 2020 seems strange but check the bearings. I had a rear that seemed fine till I noticed the tire was crooked one day looking at it from the back. bearing was toasted but it wasn't noisy, the drum was keeping it together and slowly milling itself down. might cause binding or rubbing when weight and force are applied but not when its up in the air. also check radius rods and control arm for bad bushings or loose bolts. It might be fine in the air but once you put weight on the car things could tweek out of alignment Link to comment Share on other sites More sharing options...
Ionstorm66 Posted October 7, 2020 Author Share Posted October 7, 2020 1 hour ago, djellum said: seems strange but check the bearings. I had a rear that seemed fine till I noticed the tire was crooked one day looking at it from the back. bearing was toasted but it wasn't noisy, the drum was keeping it together and slowly milling itself down. might cause binding or rubbing when weight and force are applied but not when its up in the air. also check radius rods and control arm for bad bushings or loose bolts. It might be fine in the air but once you put weight on the car things could tweek out of alignment The do alignments with the tires on the ground, so anything like that would show up on an alignment. Something has to be different when driving. I need some clear weather to swap radius rods. Link to comment Share on other sites More sharing options...
Dee2 Posted October 7, 2020 Share Posted October 7, 2020 You can also tell if the bearings are bad by simply checking for wheel movement. Raise the wheel off the ground a few inches. With your hands at the 6 and 12 o'clock positions rock the wheel by pushing and pulling. Any clunking or free play will mean the bearings are gone. 1 Link to comment Share on other sites More sharing options...
el_freddo Posted October 9, 2020 Share Posted October 9, 2020 On 10/7/2020 at 1:56 PM, Ionstorm66 said: The do alignments with the tires on the ground, so anything like that would show up on an alignment. Something has to be different when driving. I need some clear weather to swap radius rods. Not necessarily. If they just set and forget there could be many underlying issues that come into play once you drive off and things start moving as the suspension does its thing. Cheers Bennie 1 Link to comment Share on other sites More sharing options...
