xXArchusXx Posted September 28, 2020 Share Posted September 28, 2020 going to look at an xt and its a na with an auto. it has 160k miles. been sitting for a while. want to compression check the engine, what are the numbers for a healthy engine? how long will it take to do? Im guessing take out the efi fuse or is there another fuse? thanks for the help. i will use it as a daily driver and wont be racing it or redlining it. it is red and beige interior. Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 28, 2020 Share Posted September 28, 2020 (edited) I would just change the oil and fuel, and start it first. No reason to mess with compression unless it runs. Fuel is easy, just pull the hose going into the fuel filter off. Extend it with some more hose into a jug. Connect the green connectors and turn the key on. It will cycle the pump on and off. Keep pumping until its all out. Then look at the fuel and see if there is a lot of curd. If it looks clear, throw 5 gallons in, hook the hose back up, unplug the connector and see if she runs. PS: white on black text is a pain to read! Edited September 28, 2020 by Ionstorm66 1 Link to comment Share on other sites More sharing options...
idosubaru Posted September 28, 2020 Share Posted September 28, 2020 Prop open throttle plate, disable fuel pump (there’s a plug on pump under car in front of p/s rear wheel) test. Or pull the fuel hose in the engine bay and place it in a bottle surrounded by a towel so you can see what the fuel looks like at the same time. I doubt I’d bother, whatever issues it has won’t likely be compression. Or, if it is you can probably tell by seeing if the radiator is full or empty/antifreeze or water or it’s been abused. Link to comment Share on other sites More sharing options...
xXArchusXx Posted September 28, 2020 Author Share Posted September 28, 2020 Is a healthy engine. The cruise control don't work. It needs several days of cleaning. The drivers seatbelt doesn't go forward when going out. The air hot cold thing is stuck in the hot. Has that old car smell to it. Has a couple of buttons can't figure out where they go. Missing a center cap. Got it for $1200 the dang antenna still goes up n down. The drivers seatbelt top thing needs the panel fitted. Link to comment Share on other sites More sharing options...
xXArchusXx Posted September 28, 2020 Author Share Posted September 28, 2020 Oil pressure Drops when at idle. Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 28, 2020 Share Posted September 28, 2020 On 9/28/2020 at 10:16 PM, xXArchusXx said: Is a healthy engine. The cruise control don't work. It needs several days of cleaning. The drivers seatbelt doesn't go forward when going out. The air hot cold thing is stuck in the hot. Has that old car smell to it. Has a couple of buttons can't figure out where they go. Missing a center cap. Got it for $1200 the dang antenna still goes up n down. The drivers seatbelt top thing needs the panel fitted. Expand Is it factory cruise control, or aftermarket? Factory cruise control has a button on the dash under the defrost, and controls on the wheel. So if you look under the rear seat on the wall of the foot well there is a small bag with an allen wrench. That is for the seatbelts. You can put it in a hole behind the drivers seat and move the belt manually. Move it all the way back and forth, it should free up. Might start working then. Next I would check the door switch. The hot/cold is a pair for cables. You can remove the selector buttons, and pull out the controls. Then carefully remove the cables. They are attached on the other end, so pulling one should push the other. See if you can move them with some pliers, only pull the cable that is shorter. Squirt some lube on the cable as you pull the other cable. Which buttons cant you figure out? Show some pictures. Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 28, 2020 Share Posted September 28, 2020 On 9/28/2020 at 10:24 PM, xXArchusXx said: Oil pressure Drops when at idle. Expand How low dose the oil get? It's pretty normal for these to only have 10-15 psi at idle. Link to comment Share on other sites More sharing options...
xXArchusXx Posted September 28, 2020 Author Share Posted September 28, 2020 On 9/28/2020 at 10:26 PM, Ionstorm66 said: Is it factory cruise control, or aftermarket? Factory cruise control has a button on the dash under the defrost, and controls on the wheel. So if you look under the rear seat on the wall of the foot well there is a small bag with an allen wrench. That is for the seatbelts. You can put it in a hole behind the drivers seat and move the belt manually. Move it all the way back and forth, it should free up. Might start working then. Next I would check the door switch. The hot/cold is a pair for cables. You can remove the selector buttons, and pull out the controls. Then carefully remove the cables. They are attached on the other end, so pulling one should push the other. See if you can move them with some pliers, only pull the cable that is shorter. Squirt some lube on the cable as you pull the other cable. Which buttons cant you figure out? Show some pictures. Expand Thank you. I'll get some pictures when I get back from an appointment. The cruise control is factory and it's an auto tranny. The buttons by the horn. Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 28, 2020 Share Posted September 28, 2020 On 9/28/2020 at 10:30 PM, xXArchusXx said: Thank you. I'll get some pictures when I get back from an appointment. The cruise control is factory and it's an auto tranny. The buttons by the horn. Expand Nice, the factory cruise control is pretty rare. I only seen one IRL and it was a GL-10 wagon. Link to comment Share on other sites More sharing options...
xXArchusXx Posted September 28, 2020 Author Share Posted September 28, 2020 On 9/28/2020 at 10:33 PM, Ionstorm66 said: Nice, the factory cruise control is pretty rare. I only seen one IRL and it was a GL-10 wagon. Expand At idle it sometimes makes some weird noises. Bad fuel? Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 28, 2020 Share Posted September 28, 2020 On 9/28/2020 at 10:46 PM, xXArchusXx said: At idle it sometimes makes some weird noises. Bad fuel? Expand Oh I didnt see it was an XT. I think all of them had CC. The engine is the same unless its a XT6. What do you mean weird noise? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 28, 2020 Share Posted September 28, 2020 On 9/28/2020 at 10:46 PM, xXArchusXx said: At idle it sometimes makes some weird noises. Bad fuel? Expand That's the sound of all the money in your wallet being sucked into a black hole while you attempt to daily drive a 30+ year old car that's been sitting. GD 1 Link to comment Share on other sites More sharing options...
xXArchusXx Posted September 29, 2020 Author Share Posted September 29, 2020 On 9/28/2020 at 10:55 PM, Ionstorm66 said: Oh I didnt see it was an XT. I think all of them had CC. The engine is the same unless its a XT6. What do you mean weird noise? Expand It's a H6 I'm getting a battery. What windshield wipers do I get it looks weird Link to comment Share on other sites More sharing options...
DaveT Posted September 29, 2020 Share Posted September 29, 2020 No doubt the fuel is bad, if it's been in there over a year. As you start to run it, you'll be finding all the things that need attention. Keeping the cooling system in top condition is the most important thing. Every bit of it, from the multiple hoses to the radiator. Non XTs have 7 hoses, I don't know XTs, but they should be similar. The hardest part of trying to make this a daily driver is getting the NLA parts. You have to scrounge, buy parts cars, DIY most repairs. Link to comment Share on other sites More sharing options...
xXArchusXx Posted September 29, 2020 Author Share Posted September 29, 2020 On 9/29/2020 at 12:39 AM, DaveT said: No doubt the fuel is bad, if it's been in there over a year. As you start to run it, you'll be finding all the things that need attention. Keeping the cooling system in top condition is the most important thing. Every bit of it, from the multiple hoses to the radiator. Non XTs have 7 hoses, I don't know XTs, but they should be similar. The hardest part of trying to make this a daily driver is getting the NLA parts. You have to scrounge, buy parts cars, DIY most repairs. Expand I'll do all the repairs except maybe the timing belt. Link to comment Share on other sites More sharing options...
xXArchusXx Posted September 29, 2020 Author Share Posted September 29, 2020 On 9/28/2020 at 10:58 PM, GeneralDisorder said: That's the sound of all the money in your wallet being sucked into a black hole while you attempt to daily drive a 30+ year old car that's been sitting. GD Expand its just a tensioner or something. Link to comment Share on other sites More sharing options...
el_freddo Posted September 29, 2020 Share Posted September 29, 2020 On 9/29/2020 at 12:48 AM, xXArchusXx said: I'll do all the repairs except maybe the timing belt. Expand That’s an easy one, you’ll be fine. Cheers Bennie Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 29, 2020 Share Posted September 29, 2020 On 9/29/2020 at 12:48 AM, xXArchusXx said: I'll do all the repairs except maybe the timing belt. Expand Timing belt on a EA is about as easy as timing belts come. You can do in an about an hour with the engine in. The hardest part is getting the vbelt stuff out of the way. My tip for that is remove the alt and ac compressor bracket, plus the battery. Helps you get to the fan/water pump pulley better. Link to comment Share on other sites More sharing options...
xXArchusXx Posted September 29, 2020 Author Share Posted September 29, 2020 On 9/29/2020 at 2:21 AM, Ionstorm66 said: Timing belt on a EA is about as easy as timing belts come. You can do in an about an hour with the engine in. The hardest part is getting the vbelt stuff out of the way. My tip for that is remove the alt and ac compressor bracket, plus the battery. Helps you get to the fan/water pump pulley better. Expand its up front there isnt a cover or anything, i can do it but it looks like the belt there is brand new. the glove box wont close lol. Link to comment Share on other sites More sharing options...
idosubaru Posted September 29, 2020 Share Posted September 29, 2020 On 9/28/2020 at 10:24 PM, xXArchusXx said: Oil pressure Drops when at idle. Expand Normal. Owners manual or a TSB from Subaru mentioned it long ago. Also the sender and gauges are ancient and likely not accurate. Highly unlikely to have oil pressure issues, put a real gauge on it to check if you’re worried. wipers - get an adapter to use regular blades. They’re basically Subaru only unless you get an adapter. It’s super simple. Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 29, 2020 Share Posted September 29, 2020 (edited) On 9/29/2020 at 2:25 AM, xXArchusXx said: its up front there isnt a cover or anything, i can do it but it looks like the belt there is brand new. the glove box wont close lol. Expand You can see the serpentine belt on the AC/Alt/Waterpump AND the timing belt? Its pretty common to leave the covers off. They are half the timing belt job. Check down for my post on wiper blades. Edited September 29, 2020 by Ionstorm66 Link to comment Share on other sites More sharing options...
idosubaru Posted September 29, 2020 Share Posted September 29, 2020 (edited) On 9/29/2020 at 2:25 AM, xXArchusXx said: its up front there isnt a cover or anything, i can do it but it looks like the belt there is brand new. the glove box wont close lol. Expand Yeah those glove box key mechanisms fall apart all the time now that they’re old. If it’s there try to fix it, they’re usually a high demand item as far as XTs go. Edited September 29, 2020 by idosubaru Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 29, 2020 Share Posted September 29, 2020 On 9/29/2020 at 2:26 AM, idosubaru said: Normal. Owners manual or a TSB from Subaru mentioned it long ago. Also the sender and gauges are ancient and likely not accurate. Highly unlikely to have oil pressure issues, put a real gauge on it to check if you’re worried. wipers - get an adapter to use regular blades. They’re basically Subaru only unless you get an adapter. It’s super simple. Expand My aftermarket gauge matches my dash gauge for oil pressure. I have a 92, so its possible the gauge/sender is better. They are super common to get plugged with sludge, making them read poorly at low pressures. Link to comment Share on other sites More sharing options...
xXArchusXx Posted September 29, 2020 Author Share Posted September 29, 2020 On 9/29/2020 at 2:27 AM, idosubaru said: Yeah those glove box key mechanisms fall apart all the time. If it’s there try to fix it, they’re usually a high demand item as far as XTs go. Expand there is a key thing but it falls out, On 9/29/2020 at 2:26 AM, Ionstorm66 said: You can see the serpentine belt on the AC/Alt/Waterpump AND the timing belt? Its pretty common to leave the covers off. They are half the timing belt job. Expand there is nothing ontop of the engine. its a H6 engine so idk. there is a belt on the ac and stuff but there may be another belt I haven't looked that deep yet. On 9/29/2020 at 2:26 AM, idosubaru said: Normal. Owners manual or a TSB from Subaru mentioned it long ago. Also the sender and gauges are ancient and likely not accurate. Highly unlikely to have oil pressure issues, put a real gauge on it to check if you’re worried. wipers - get an adapter to use regular blades. They’re basically Subaru only unless you get an adapter. It’s super simple. Expand thanks for the info. the gauge has 160k miles on it so its probably old. do you recommend a specific wiper adaptor? Link to comment Share on other sites More sharing options...
idosubaru Posted September 29, 2020 Share Posted September 29, 2020 On 9/29/2020 at 2:36 AM, xXArchusXx said: there is a key thing but it falls out, there is nothing ontop of the engine. its a H6 engine so idk. there is a belt on the ac and stuff but there may be another belt I haven't looked that deep yet. thanks for the info. the gauge has 160k miles on it so its probably old. do you recommend a specific wiper adaptor? Expand you can reseal the oil pump and shim the pressure relief or stretch the springs in the heads for better oil pressure. I don’t know part number or brand for XT adapter. Here’s an example. https://www.amazon.com/Windshield-Wiper-Adapter-Bosch-3392390298/dp/B015YD1US8/ref=asc_df_B015YD1US8/?tag=hyprod-20&linkCode=df0&hvadid=241969781511&hvpos=&hvnetw=g&hvrand=13838419871965489114&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9009441&hvtargid=pla-571072893796&psc=1 I bought a few adapters like 20 years go and have never needed to look since, so that probably isn’t the same brand or identical. But it’s very similar if it’s not. Link to comment Share on other sites More sharing options...
