Ionstorm66 Posted September 28, 2020 Share Posted September 28, 2020 (edited) Here is my 1992 Loyale Wagon 5 speed 4WD. I bought it to replace my completely rusted '89 2WD auto DL sedan. Mods: Rear struts from 1998 4RUNNER Monroe 71352 Springs from a 1989 Accord API 270470595 with one coil cut off. $20 Walmart headunit with $25 Walmart 5.5" speakers in all 4 door. Ran new grounds to the fronts. $50 Used 10 inch sub with amp in way to small of a box.\ Plans: New front struts with kia spings 4 channel amp Roofrack Lights Keyless entry Edited September 28, 2020 by Ionstorm66 Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 28, 2020 Author Share Posted September 28, 2020 (edited) Pics: Practical! Current trunk situation: Engine Bay all stock minus amp wire and full size spare: Edited October 10, 2020 by Ionstorm66 Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 28, 2020 Author Share Posted September 28, 2020 (edited) Table of contents (links): Rear Springs and Struts Edited September 28, 2020 by Ionstorm66 Link to comment Share on other sites More sharing options...
Ionstorm66 Posted September 28, 2020 Author Share Posted September 28, 2020 (edited) Rear Springs and Struts I ordered from rock auto as they have clearance on the struts and the springs! I used API 270470595 coil springs and Monroe 71352 struts. Total was $82 shipped! My only issue was the Monroe struts come with a cover for the rod. It has a metal washer to hold it on the top of the strut rod. The problem is this washer is larger than the relief in the Subaru cap. This causes you to be unable to install the top bushings. I omitted the cover, and ordered some generic ones. I initially thought the spring was too long, and cut one. I did test the second without cut just to see how much I lost. You can see the cover on the right: Stock vs Uncut and Struts: My wagon started with the right touching the bump stop due to my tools in the back. Numbers: 24.5" Before 27" Cut 28.25" Uncut Stock: Cut spring: Uncut: Edited October 10, 2020 by Ionstorm66 Link to comment Share on other sites More sharing options...
Hex1 Posted October 9, 2020 Share Posted October 9, 2020 (edited) How are the springs and struts working out? None of those images loaded for me Edited October 9, 2020 by Hex1 Link to comment Share on other sites More sharing options...
Ionstorm66 Posted October 10, 2020 Author Share Posted October 10, 2020 18 hours ago, Hex1 said: How are the springs and struts working out? None of those images loaded for me Try the pic now, should be fixed. Only issue is the flats on the shaft are too long after you tighten the nuts. So on hard bumps they hit the body. I lift would solve this, but I just cut off the flats. Link to comment Share on other sites More sharing options...
