1992 Loyale: need advice
Hello all I am new here. I just bought a 1992 Loyale base wagon with 1.8 and 3 speed auto tranny. The car is absolutely mint and only 133k miles but I just found out the motor has a spun bearing. I cant find a motor or someone to rebuild mine here in AZ. Any ideas? I really don't want to spend too much more on it. I can't part it out as my HOA wont allow that. Any ideas?
Also I would baulk at 260k. It still has good oil pressure, and all the lifters are still working. You keep the oil clean and at pressure, an EA82 will last a long time.
The normal culprits for killing them are oil pump gasket and timing belt snapping which kills the oil pressure, or just all the oil leaking out.
Overheating/bad headgaskets only really kills the EA82Ts because the heads crack.
Edited by Ionstorm66
