SubaruProjectD Posted October 7, 2020 Share Posted October 7, 2020 (edited) Hi everyone I need you guys help. I just picked up an 86 gl-10 turbo fwd automatic tranny 4 door coupe. I am planning to convert it to awd. Will parts from a 88 gl Wagon non turbo work for the conversion or does it have to be a gl-10 turbo model like mine? Any help will be appreciated. Edited October 7, 2020 by SubaruProjectD Quote Link to comment Share on other sites More sharing options...
DaveT Posted October 7, 2020 Share Posted October 7, 2020 If you get the awd transmission from another GL10 with awd, and the rest of the drive parts, it should be no problem. The non 10 transmission will bolt onto the engine, but I don't know about the mounting / body dimensions. You do want to get the transmission and diff from one car. Might as well get the trailing arms, driveshaft and axles too. Quote Link to comment Share on other sites More sharing options...
Ionstorm66 Posted October 7, 2020 Share Posted October 7, 2020 2 hours ago, SubaruProjectD said: Hi everyone I need you guys help. I just picked up an 86 gl-10 turbo fwd automatic tranny 4 door coupe. I am planning to convert it to awd. Will parts from a 88 gl Wagon non turbo work for the conversion or does it have to be a gl-10 turbo model like mine? Any help will be appreciated. the non turbo will have a higher gear ratio. While it wont prevent the swap due to you swaping trans and rear diff, it will make the car more sluggish. Quote Link to comment Share on other sites More sharing options...
SubaruProjectD Posted October 8, 2020 Author Share Posted October 8, 2020 2 hours ago, DaveT said: If you get the awd transmission from another GL10 with awd, and the rest of the drive parts, it should be no problem. The non 10 transmission will bolt onto the engine, but I don't know about the mounting / body dimensions. You do want to get the transmission and diff from one car. Might as well get the trailing arms, driveshaft and axles too. I just talked to the person selling the parts and he said it’s from a turbo gl wagon will it work since it’s a turbo and what other parts do i need besides the transmission for it to make it awd he said I need the shifting lever since it has a push button on it for the awd? Quote Link to comment Share on other sites More sharing options...
DaveT Posted October 8, 2020 Share Posted October 8, 2020 Mostly turbo vs non is engine and ECU differences. There are various transmissions, those may make differences. It's safest to get the entire car if possible. IF not, I would want everything in the drive lines from the transmission to the tires. Depending on the transmission controls, the wiring harness involved, and or an vacuum stuff involved. Check what kind of rear brakes both have also. Many parts for these are getting rare / hard to find / NLA, so collecting them is a good idea. There are a couple of transmissions that are different. I am most familiar with non turbo EA82 powered automatics, the 3AT 4WD transmission. There were a few that were AWD, most common is 4WD. There is a difference. Quote Link to comment Share on other sites More sharing options...
Ionstorm66 Posted October 8, 2020 Share Posted October 8, 2020 (edited) Are they both the same trans? There are 3 speeds and 4 speeds. Swapping between them would be a ton of work. The 3 speeds are dead nuts simple. All hydraulic control with just a single solenoid for 4WD. Send 12V to it for 4WD. The 4 speeds are electronic control. You have to do a ton of harness work, swap the dash etc, to get a 4 speed in a 3 speed car. Edited October 8, 2020 by Ionstorm66 2 Quote Link to comment Share on other sites More sharing options...
SubaruProjectD Posted October 8, 2020 Author Share Posted October 8, 2020 Mine is 3speed and his is 3 speed Quote Link to comment Share on other sites More sharing options...
Ionstorm66 Posted October 8, 2020 Share Posted October 8, 2020 17 minutes ago, SubaruProjectD said: Mine is 3speed and his is 3 speed Pretty simple swap. Best if you can get both cars in the same place. 1 Quote Link to comment Share on other sites More sharing options...
SubaruProjectD Posted October 8, 2020 Author Share Posted October 8, 2020 Do I need the gas tank? Quote Link to comment Share on other sites More sharing options...
Ionstorm66 Posted October 8, 2020 Share Posted October 8, 2020 1 hour ago, SubaruProjectD said: Do I need the gas tank? Yes. Off the top of my head: Trans Driveshaft Carrier Bearing Diff fuel tank Diff mounts axles hubs shifter wiring 1 Quote Link to comment Share on other sites More sharing options...
