EJ fuel injected or Weber and Escort distributor
  On 10/7/2020 at 8:49 PM, George1943 said:
Does anyone know the approximate HP difference between a '95 fuel injected EJ22 and one that has been converted to a Weber and an Escort distributor?
Expand
Tuned correctly it will be the same. Tuning an EFI car is much easier. If you're already using a stock ECU that is correct for the application, no tuning needed.
Expand
Doing a factory efi EJ22 install is much easier than fabricating parts for dizzy and Weber in my book.
Cheers
Bennie
I would love to see evidence that a single or twin barrel carb can get the same performance as a MPFI setup. Carb vs SPFI I'd agree, MPFI I doubt very much. Even Subaru's own EA82 shows a marked improvement from carb to MPFI (9kW, minus what was gained from increasing the C/R).
Expand
Wasn't just MPFi that changed the EA82 MPFi, it got quad runner intake manifolding and twin intake port heads
