Ionstorm66 Posted October 17, 2020 Share Posted October 17, 2020 So my car is always low on coolant so my last two oil changes I measured it. For 5000 miles it's about a cup. I can't see any leaks, and passenger side foot well is dry. Just did my timing belts and didn't see anything on the water pump. Maybe a pinhole in the rad? Link to comment Share on other sites More sharing options...
Step-a-toe Posted October 17, 2020 Share Posted October 17, 2020 (edited) Perspiration in its socks? Sort of why we need to check and top up, I know, it must be going somewhere ! We have a 16 year old that has never been changed or topped up since factory...noticed other day the level has dropped and one of the hardest to access hose has green whiskers ....so , not gonna make 17 years. Your case is good contender for a chunk of Sealwel Edited October 17, 2020 by Step-a-toe Link to comment Share on other sites More sharing options...
DaveT Posted October 18, 2020 Share Posted October 18, 2020 Intake manifold gaskets. One of the 7 cooling system hoses. Radiator in poor condition. Check it at least once per day. Even then, some of these can fail worse suddenly, leaving you low on coolant and over normal temperature. If that happens, sooner or later, head gaskets. Check things until you find it and fix it. 1 Link to comment Share on other sites More sharing options...
Step-a-toe Posted October 18, 2020 Share Posted October 18, 2020 Not that previous owners of any old cars I have bought would know, a radiator cap is a service item. Easily and cheaply replaced. Can do wonders Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 18, 2020 Share Posted October 18, 2020 you could try the Subaru Coolant Conditioner (rebranded Holt's Radweld) - 1 bottle only, installed per directions ONLY. 1 Link to comment Share on other sites More sharing options...
Ionstorm66 Posted October 19, 2020 Author Share Posted October 19, 2020 On 10/18/2020 at 5:03 AM, DaveT said: Intake manifold gaskets. One of the 7 cooling system hoses. Radiator in poor condition. Check it at least once per day. Even then, some of these can fail worse suddenly, leaving you low on coolant and over normal temperature. If that happens, sooner or later, head gaskets. Check things until you find it and fix it. Expand I've replaced all the hoses and I rebuilt the intake manifold last year after an injector o-ring died. Possible I messed up the gasket, would explain why I can't find the leak. It's such a slow leak I don't see any smoke. The radiator looks good, I can't see any coolant residue on it. I'm just worried it's the heater core, so I keep looking for something in the engine bay to blame it on lol. Link to comment Share on other sites More sharing options...
DaveT Posted October 19, 2020 Share Posted October 19, 2020 Yes, it takes a pretty good leak to get visible smoke from the intake gasket leak. The gaskets I use are the Subaru made ones, they are not cardboard. I've had those cardboard aftwrmarket ones fail at least twice in me. And they were Fel Pro brand. Link to comment Share on other sites More sharing options...
