vtscooby Posted October 18, 2020 Share Posted October 18, 2020 1994 Subaru Loyale -- that will NOT Start -- 1.8 engine - Throttle body Fuel Injected 4WD Standard Transmission Fuel Pump comes on... Has NO spark... Intermittent electrical issue -- Several times in the last few weeks it would not start -- & then is would after a bit... Got me home and now it will not start... Turns over -- Checked timing belts -- Distributor's Rotor Turns with cap off... [screw is tight in Rotor] Changed coil & ignition unit Changed Distributor -- with NEW Cap and Rotor Changed relays above Computer! ------------------------- Noticed something here: NO lights on Computer! -- LED Light Blinks NOTHING? Also -- when you first turn the key on NO [C.E.L.] on Dash -- Changed THREE different Computers all act the same way!? NO blinking led light on computer -- not five or seven pattern -- NOTHING... Let me know what direction I should to go in now? Thanks for your time and consideration! VTSCOOBY-- Link to comment Share on other sites More sharing options...
john in KY Posted October 19, 2020 Share Posted October 19, 2020 I know from experience that the coil bracket must be well grounded. Very remote possibility that small whatever it is called that is riveted to the bracket has failed. Link to comment Share on other sites More sharing options...
