Rear Hub 2010 + fit older Subaru?
Looking for a friend who has a 2007 Subaru that need rear wheel bearings, I came across the replaceable unit, 2010+
Is it possible to get a newer unit and retro fit it to an earlier Subaru?  If you went to the yard and pulled a 2010+ rear hub, could it be bolted in to an earlier Subaru?
Thanks,
Larry
Depends. 2005+ Legacy rear bearings are bolt-in. Impreza did not get any bolt-in bearings front or rear till 2008. I couldn't tell you what will interchange without model information and in any case it's easy to lookup the parts on parts.subaru.com and check the interchange.
Edited by GeneralDisorder
On 11/14/2020 at 6:45 PM, lmdew said:
a 2007 Subaru...
Subaru, what.
Rear bearings went to bolt in hub assemblies when the rear suspension went to multi-link, so the knuckles are completely different.
So, ASSuming this 2007 Subaru is Impreza based, you get press in bearings.
