Zugzwang Posted December 14, 2020 Share Posted December 14, 2020 So I've seen a few videos of transmission adaptation. Where a different makes transmission is mated with the original engine through an aluminum plate. It's a little bit of work but I was wondering if anyone has already completed a transmission swap and if so could I get the details. Link to comment Share on other sites More sharing options...
el_freddo Posted December 14, 2020 Share Posted December 14, 2020 What transmission do you want to put in and why? The L series 5 speed gearbox is the most common conversion and does not require an adaptor plate when using the EA81 engine. Cheers Bennie Link to comment Share on other sites More sharing options...
