Hello, just got a 99 legacy outback with a blown ej25 in it for dirt cheap and looking to get a jdm replacement but I want to know if I can swap a turbo motor and if so which one is the easiest and most reliable. Also what all would be needed for the swap. Any help would be much appreciated.
You’ll need the matching engine management loom and ECU.
Then splice this into the vehicle’s main loom so it works. If you have security that’s an added challenge.
Or run an aftermarket loom and engine management.
Other supporting mods that could be done are larger brakes. You’ll need an upgraded fuel pump.
Best to buy a turbo vehicle from the get go and star with that base.
Cheers
Bennie
Unless you enjoy wrestling in piles of wiring labelling, cutting, splicing...the wiring alone isn't worth it, not even counting the mechanical work.  engine, exhaust, turbo, wiring, ECU, and crossmember to clear the turbo pipe unless you're going to custom fab an exhaust around the existing crossmember or cut and weld/fab your own crossmember.
