Ionstorm66 Posted December 20, 2020 Share Posted December 20, 2020 I can't seem to keep a alternator belt for more than 5-10k miles. They burn up and drop down into the v so much they slip. It's a factory AC car and I replaced the AC belt when I got it over 40k ago. AC belt looks mint. I can't see any wobble or damage to the alternator pulley and it looks aligned. Is it possible I'm over tightening the alternator? Quote Link to comment Share on other sites More sharing options...
DaveT Posted December 20, 2020 Share Posted December 20, 2020 This is odd. I've been running EA82s since 1988, never seen this. I run NAPA fleet belts. Don't even remember the last time I had to buy them, they are still good, moved from car - car. Tighten the Alternator belt just tight enough so the alternator sheave doesn't slip when you try to turn it by hand. Not through the compression stroke, just in the slack time [angles] between. I found that it's good to re check the belt tensions after a short run if you have dual belts. 1 Quote Link to comment Share on other sites More sharing options...
Dee2 Posted December 21, 2020 Share Posted December 21, 2020 Quote They burn up and drop down into the v so much they slip. A burned belt will slip. A new belt should be fitting down into the V. Sounds like you may be buying the wrong size of belt width. Quote Link to comment Share on other sites More sharing options...
Ionstorm66 Posted December 23, 2020 Author Share Posted December 23, 2020 On 12/21/2020 at 4:44 PM, Dee2 said: A burned belt will slip. A new belt should be fitting down into the V. Sounds like you may be buying the wrong size of belt width. The AC belt fits like a champ, and I'm running the belts the manual calls for. I think it's a bag alternator pulley. The rest of the pulleys fit it fine. A V belt should right on the sides not the bottom. If they ride on the bottom it wears the sides off, which will eventually cause it to slip. Quote Link to comment Share on other sites More sharing options...
Ionstorm66 Posted December 26, 2020 Author Share Posted December 26, 2020 So I pulled the pulley off my parts car and it fits way better. Wonder if my other pulley was way over tightened causing it to spread open? Quote Link to comment Share on other sites More sharing options...
mickytrus Posted December 27, 2020 Share Posted December 27, 2020 What you mentioned about it being spread open... make sense... why it was wearing out....... it was eating the internal diameter up..... thus falling in.ward..... the belt's tension was not on it's side but on it's bottom.......(more like a car tire) pulley should remediate your prob I would think... Any thoughts on how it became spread open? Just curious.... Micky Quote Link to comment Share on other sites More sharing options...
