5000fingers Posted January 9, 2021 Share Posted January 9, 2021 I have a 2011 outback, which just started with a clicking sound, regularly and every few seconds, underneath the passengers seat, even with the key off. It drains the battery. It sounds like a relay clicking. Is there a relay under there? What else could be causing it? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
brus brother Posted January 10, 2021 Share Posted January 10, 2021 Have you tried pulling fuses to see what circuit has gone gerfarkt? Can you see any relays beneath the seat? Have you recently installed any aftermarket equipment? radio, lights etc? Make sure nothing has been jammed beneath the seat. water bottle, kid's feet that could have disengaged a connector. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 10, 2021 Share Posted January 10, 2021 front or rear pass seat? Some newer models regularly do an evap pressure test. If it is clicking more than 3-4 times a day however, could be a failure of some sort. is the CEL on? maybe scan for codes. Quote Link to comment Share on other sites More sharing options...
Mrineck Posted December 20, 2021 Share Posted December 20, 2021 Did you ever figure out this issue? Experiencing the same issue with my Outback Quote Link to comment Share on other sites More sharing options...
