1197sts Posted January 15, 2021 Share Posted January 15, 2021 I need to change the trans mount on a 2000 Outback, Auto trans. I see that there are two types available, it originally came with a 4 stud design, it appears there are 3 stud designs available as well. Anyone with experience on these, does it make a difference? Link to comment Share on other sites More sharing options...
idosubaru Posted January 15, 2021 Share Posted January 15, 2021 (edited) On 1/15/2021 at 5:47 PM, 1197sts said: I need to change the trans mount on a 2000 Outback, Auto trans. I see that there are two types available, it originally came with a 4 stud design, it appears there are 3 stud designs available as well. Anyone with experience on these, does it make a difference? Expand where are you getting your information from? I'd guess there's just an auto trans and manual trans mount. All 2000 auto transmissions are interchangeable so there can't be two different, incompatible mounts for them. Edited January 15, 2021 by idosubaru Link to comment Share on other sites More sharing options...
heartless Posted January 16, 2021 Share Posted January 16, 2021 (edited) looking on Rock Auto, there are indeed 2 different mounts listed for auto trans (manual is in a completely different section and has 2 studs).. one has 3 studs, the other 4 studs, just as he described.. if it were me, i would be checking to see what the car has currently, and go with whichever that is. Edited January 16, 2021 by heartless Link to comment Share on other sites More sharing options...
idosubaru Posted January 16, 2021 Share Posted January 16, 2021 On 1/16/2021 at 10:27 AM, heartless said: if it were me, i would be checking to see what the car has currently, and go with whichever that is. Expand yes this. I was speaking about the body side of the mounts and have a real bad incomplete answer. match whatever transmission will be in the vehicle. Theres a few variables between 00-01: 99/00 generation crossover, H6 is introduced, and Impreza/Outback differences, and maybe Phase I and II trans depending where you’re looking. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 16, 2021 Share Posted January 16, 2021 if you could purchase from a supplier that has a free return policy - probably a local place? - buy both types, return the unused one. Link to comment Share on other sites More sharing options...
1197sts Posted January 16, 2021 Author Share Posted January 16, 2021 Thanks for the input, I have checked out a 2000 and a 2001 Outback and they both originally had the 4 stud style. I have a commercial parts source and it seems to indicate 3 stud style supersedes the 4 stud style, the question is does it fit the original crossmember and I am hoping it does. I was hoping someone had encountered this before. Link to comment Share on other sites More sharing options...
