turbodog Posted February 17, 2021 Share Posted February 17, 2021 i need a new headgasket, is fel-pro the go 2? has anyone had good luck with others? Link to comment Share on other sites More sharing options...
DaveT Posted February 17, 2021 Share Posted February 17, 2021 I've had good luck with fel pro for the non turbo EA82s. For the intake gaskets, and o rings for the oil passages, dealer only. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 17, 2021 Share Posted February 17, 2021 Fel-Pro seems to work OK for the head gaskets. The rest of the gaskets they include are garbage and you need to get those from the dealer. GD Link to comment Share on other sites More sharing options...
idosubaru Posted February 17, 2021 Share Posted February 17, 2021 (edited) 15 hours ago, turbodog said: i need a new headgasket, is fel-pro the go 2? has anyone had good luck with others? what he said - FP headgaskets, the rest from dealer. the FP kit won't have the reinforced metal orings for the lower corner of the cam carrier, or none that I've ever seen have it anyway. intake manifold, tstat, water pump, exhaust are all better quality from dealer. sometimes I might use FP valve cover gaskets but mostly just because if they do fail again it's just a minor oil leak and they're easy to replace. i don't want that risk or work load for intake mani or coolant. Edited February 17, 2021 by idosubaru Link to comment Share on other sites More sharing options...
turbodog Posted February 17, 2021 Author Share Posted February 17, 2021 yeah, sounds good, and yeah i dont like to use crappy aftermarket gaskets. that oem thermostat is massive Link to comment Share on other sites More sharing options...
