80BratGage Posted March 21, 2021 Author Share Posted March 21, 2021 Another thing , the car will turn over without the clutch being applied, does this have a clutch switch? Link to comment Share on other sites More sharing options...
80BratGage Posted March 22, 2021 Author Share Posted March 22, 2021 She fired and is idling ! Ran a tank through the lines but just ran it to a bucket and finally got lightly tinted gas. Link to comment Share on other sites More sharing options...
moosens Posted March 22, 2021 Share Posted March 22, 2021 No switch on the clutch. It’s old school dangerous. My first guess would be float level. 1 Link to comment Share on other sites More sharing options...
moosens Posted March 22, 2021 Share Posted March 22, 2021 Could have had slightly clogged jet and now clearing out some. Always best to soak the body and blow out jets. And the sight glass on the left side will show the float level if the glass isn’t fogged out. You’ve probably adjusted a similar float before. Easy but patience required at times. Link to comment Share on other sites More sharing options...
80BratGage Posted March 23, 2021 Author Share Posted March 23, 2021 I actually took carb off re cleaned jets and after I put her back she fired and sounds pretty good , Link to comment Share on other sites More sharing options...
Subasaurus Posted March 25, 2021 Share Posted March 25, 2021 lucky you managed to salvage your lines, i had to run new lines from the tank itself on mine since either something inside was blocking it that required more than 120psi, or it rusted inside the metal line itself and was blocking fuel. Link to comment Share on other sites More sharing options...
