2002 forester transmission compatibility
Hey crew,
I have a customers 2002 forester S automatic trans. 260+K miles TZ1A3ZC2AA
Its making a noise/ whine at higher speeds when you are accelerating. When you let off the gas it goes awat. to me it sounds like a bearing in the front diff.
Anyways i am doing an engine swap and was going to swap the trans since its so easy to do with the engine out.
I have a good trans from a 99 obw TZ1A2ZJEBA and a trans from a 2000 OBW TZ1A4ZCABA
Both are phase 2, 8 bolt with spin on filters...
I feel like i have done these swaps before and they worked fine..
Any thoughts?
1 minute ago, lmdew said:
As long as the Rear diff matches the Trans you are good.
yeah i was more worried about the trans computers having an issue
i think all the 99-2003 outbacks and 2000-2003 forester auto trans have a 4.44 final drive.
