Will a 2005 forester transmission bolt up to a 2002 Impreza OBS?
Hello,
My clutch and transmission have both decided to grenade, and I'm having a rough time determining which transmission can fit in my car. I have found a rolled over 2005 forester with what I need, but am not sure if the clutch slave and other things will bolt up between the 2005 and 2002. I know I will need the rear diff so the final drive will match (a welcome upgrade), but will everything else go together or are these too far apart?
Thanks,
CL
A quick look on RockAuto lists the same clutch, and same slave.
You might need stub axles. The '05 will almost certainly have male splines on the axles, where the '02 will likely have female splines. You can grab the stub axles from an older 4EAT to convert. Or grab the axles from the '05 (check the ABS tone ring. Might be different, but I doubt it).
