nick2k Posted March 5, 2021 Share Posted March 5, 2021 I'm having a hard time finding a rear caliper rebuild kit for an '86 XT; anyone know of a good source, OR Know of reasonably prices rear caliper assembly? Not having much success with AutoZone or O'Reilly's. Link to comment Share on other sites More sharing options...
idosubaru Posted March 5, 2021 Share Posted March 5, 2021 did you try rock auto and google ? I would be surprised if I didn’t have a used caliper sitting around but they’re probably everywhere, cheap, and pointless to ship. Link to comment Share on other sites More sharing options...
idosubaru Posted March 5, 2021 Share Posted March 5, 2021 Subaru says discontinued. I didn’t see one listed on rockauto lots of front stuff, no rear. I’d scour aftermarket next. Sometimes it helps to search for 1988 XT6, same rear caliper as the XT but search won’t show all the Forester “XT” stuff. Link to comment Share on other sites More sharing options...
Rampage Posted March 5, 2021 Share Posted March 5, 2021 Try HERE Summit Racing shows the Centric brand rebuild kit for the rear. Today is 3/5/2021 and the estimated shipping date is 3/29/2021. Link to comment Share on other sites More sharing options...
dfoyl Posted March 5, 2021 Share Posted March 5, 2021 The rear caliper comes in 2 size pistons - I can't recall the sizes from memory - and only one of the two sizes is readily available. The other has been sold out for some time. There are a few remanufactured options available but I have found they are poorly rebuilt using piston boots that don't fit, bleeder valves that are way too big, and no rust protection other than a coat of paint. Measure the OD of your piston, and I'll see if I can find the links I had. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 5, 2021 Share Posted March 5, 2021 can he upgrade to the style that IS available? Or maybe a brake set from a different model? Link to comment Share on other sites More sharing options...
idosubaru Posted March 7, 2021 Share Posted March 7, 2021 (edited) On 3/5/2021 at 6:15 AM, dfoyl said: The rear caliper comes in 2 size pistons - I can't recall the sizes from memory - and only one of the two sizes is readily available. The other has been sold out for some time. There are a few remanufactured options available but I have found they are poorly rebuilt using piston boots that don't fit, bleeder valves that are way too big, and no rust protection other than a coat of paint. Measure the OD of your piston, and I'll see if I can find the links I had. Are you sure there are two styles? I’d love to hear more if you got links. They’re so simple snd few changes I thought all rear EA82 was the same. Maybe early 85/86s are different? With those old cars I’d guess they’re mis-labeling kits between EA81 and EA82 or confusing the early EJ/EA overlap. Edited March 7, 2021 by idosubaru Link to comment Share on other sites More sharing options...
idosubaru Posted March 7, 2021 Share Posted March 7, 2021 On 3/5/2021 at 9:16 AM, 1 Lucky Texan said: can he upgrade to the style that IS available? Or maybe a brake set from a different model? Yep, all EA are simple, I thought there was only one rear caliper. so yes swap EA82 style if it exists or do the rear ebrake conversion rear Nissan caliper, but don’t use the ebrake. Link to comment Share on other sites More sharing options...
Crazyeights Posted March 7, 2021 Share Posted March 7, 2021 I used Impreza or early Legacy, I can't remember which, brakes on the rear my 1992 Loyale. It only takes minor modifications to make the backing plate fit. The pictures and directions are on this board. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 8, 2021 Share Posted March 8, 2021 I swapped rear Honda Calipers onto my Subie's Rear Disc Brakes, Full info, here: ~► Link to comment Share on other sites More sharing options...
