86 gl10 turbo 4*4
Hi all,
So i finally got this ea82t engine to start after many years of sitting. It has new coil, plugs, cap rotor, thermostat, vacuum lines, fuel lines, fuel pump.  Fired right up, a bit rough, leaky and smokey, but smoothed out after 15 mins of running. After it gets to temp, it has a heck of a time restarting.???? Any guidance for this. Also i did break the thermo vacuum valve and I capped off the lines that went to it..
The 4 wheel drive button does not engage the tranny....??? Ideas for that.
CTS = Coolant Temperature Sensor.
Check the vacuum lines to get the 4WD to engage.  Assuming they are the same in 1986 as 1992?  I know some cars had manual 4WD engagement, but if it has a switch, chances are it uses vacuum controlled by solenoid valves.
Coolant Temperature Sensor.  It tells the ECU the engine temp, so it can adjust the amount of fuel.  A cold engine needs a lot more fuel to get started and run.  Oppositely, if the extra fuel is fed to a hot engine, it won't want to start or run well.
The CTS is a 2 wire sensor in the lower part of the thermostat housing.
Keep your eye open for a Factory Service Manual on ebay, etc.  There is no substitute.
The actuator may not engage when stationary, unless the dog clutch/engagement mechanism is correctly aligned for it to slot in.
Or there could be a hole in the vacuum actuator or vacuum line. Time to get stuck into the system and have a good look at it.
Cheers
Bennie
Edited by el_freddo
Cheers
Bennie
Thanks bennie
