roger1 Posted July 12, 2004 Share Posted July 12, 2004 Some nice thief cut the wiring harness of stereo taking plug of stereo unit and mating connector. I have a another radio with a plug and another female connector to splice on to main harness. In reviewing the colors they don't match to wires on harness. If I have the colors that mate I can have a direction to go. Can someone help me out as I can rearrange them to work ( Ihope !) Link to comment Share on other sites More sharing options...
thealleyboy Posted July 12, 2004 Share Posted July 12, 2004 roger1 said: Some nice thief cut the wiring harness of stereo taking plug of stereo unit and mating connector. I have a another radio with a plug and another female connector to splice on to main harness. In reviewing the colors they don't match to wires on harness. If I have the colors that mate I can have a direction to go. Can someone help me out as I can rearrange them to work ( Ihope !) Rog: Sorry about your loss...hope you get a chance to confront the person responsible some day (a thief's worst nightmare!!) . I usually start by probing the bare wires independently (without the aid of a schematic). You can use a simple "light bulb tester". Just attach one end to the harness wire, and the other to chassis ground, and try various key positions. This will identify your hots pretty quickly. Then I usually break out the schematic, and verify the hots. For the speaks (if they are still there), you can rig up a homemade tester out of any radio with a speaker or headphone output. Referring to the schematic, you should be able to send a signal to each of your speaks. By process of elimination, you'll be able to identify ground, and any other leads. You may have a power antenna on that model. If you run into any probs, or need the schematic,email me. good luck, John thealleyboy@yahoo.com Link to comment Share on other sites More sharing options...
Cougar Posted July 12, 2004 Share Posted July 12, 2004 Here is a copy of a post that was from Subarutex about the same thing. Was just looking through FSM today to find this stuff. Here is the info: L - Blue B - Black Y - Yellow G - Green R - Red W - White Br - Brown Lg - Light Green Gr - Gray Ignition power source - LY Ground - B Positive right front - W Positve left front - Y Ground right side - LB Ground left side - LR Positive right rear - WL Positive left rear - YW Link to comment Share on other sites More sharing options...
hootowl53577 Posted July 5, 2005 Share Posted July 5, 2005 I looked all over the web, bought a $20 Chilton's manual. I still couldn't figure out those speaker wires. Then I found this Message board! My new stereo and speakers sound great! Thanks guys. Link to comment Share on other sites More sharing options...
Cougar Posted July 5, 2005 Share Posted July 5, 2005 Glad to hear it helped you out. Lots of good help. Link to comment Share on other sites More sharing options...
MilesFox Posted July 5, 2005 Share Posted July 5, 2005 the green wire will be hot all the time for memory the suabr has a common ground speaker, so on the aftermarket radio you will hook up the +left front, the+left rear, and only one of the grounds from the radio will be used, so the left sude front and back share the same ground, the right front and back share the same ground so you will be using the front left- and the front right-, the other rear - wires will not be used Link to comment Share on other sites More sharing options...
WJM Posted September 21, 2005 Share Posted September 21, 2005 Cougar said: Here is a copy of a post that was from Subarutex about the same thing. Was just looking through FSM today to find this stuff. Here is the info: L - Blue B - Black Y - Yellow G - Green R - Red W - White Br - Brown Lg - Light Green Gr - Gray Ignition power source - LY Ground - B Positive right front - W Positve left front - Y Ground right side - LB Ground left side - LR Positive right rear - WL Positive left rear - YW Does NOT correspond with 1986 spec GL-10 wiring. *searches more* Link to comment Share on other sites More sharing options...
WJM Posted September 21, 2005 Share Posted September 21, 2005 Connector, Stereo side (probably 1986/earl 1987 Spec) Left Side Ground- Yellow Right Side Ground- White RF- Yellow/Red RR- Grey LF- Yellow LR- Yellow/Black Connector, CAR side (1987 RX) LS Ground- Blue/Red RS Ground- Blue/Black RF- White RR- White/Blue LF- Yellow LR- Yellow/White There...lol I just got done wiring in my Pioneer MP3 headunit. Yay! Link to comment Share on other sites More sharing options...
