croak Posted May 3, 2021 Share Posted May 3, 2021 (edited) Does anyone know where to get a backup light switch for a 79 4x4? Or is there a newer one that will work by changing connectors? Edited May 4, 2021 by croak Link to comment Share on other sites More sharing options...
moosens Posted May 4, 2021 Share Posted May 4, 2021 Good question , how much different would they be in the 80’s or even 90’s ? I may actually have that in new old stock but to dig it out would be a chore. And I should have one on a tranny. I have at least a couple of the single range on demand from 75-79 and gen one Brat. I should be back at storage this weekend. If you can’t find one let me know. Link to comment Share on other sites More sharing options...
croak Posted May 4, 2021 Author Share Posted May 4, 2021 From online pics ea82 looks like it should work, I had one from a 99 ej25 it threaded in and sealed, but doesn’t work. Looks like the plunger is too short. Might just order ea82 version and give it a try. Link to comment Share on other sites More sharing options...
croak Posted May 9, 2021 Author Share Posted May 9, 2021 So I can 100% confirm, ea82 reverse light switch works with ea71 transmission (just change connectors). Which I assume means it will work for ea81 as well. EJ will fit but not work. hope that helps someone. 2 Link to comment Share on other sites More sharing options...
Subasaurus Posted May 21, 2021 Share Posted May 21, 2021 On 5/9/2021 at 6:25 PM, croak said: So I can 100% confirm, ea82 reverse light switch works with ea71 transmission (just change connectors). Which I assume means it will work for ea81 as well. EJ will fit but not work. hope that helps someone. thanks for this info! i haven't bothered with mine because i figured it was first gen specific, i can definitely find a third gen at a junkyard and get the back up switch out to put on mine. thank you! Link to comment Share on other sites More sharing options...
