comatosellama Posted June 25, 2021 Share Posted June 25, 2021 I was getting ready to put my junkyard 5mt into my Impreza, and realized the clutch fork from the 2002 trans is too long for the 1996 trans. Should I just order the stock clutch fork for the 1996 transmission and use that? Thanks, CL Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 25, 2021 Share Posted June 25, 2021 unless you have upgraded clutch and power, I'd think stock would be OK. If clutch has been upgraded, some stock forks will crack/fail. Some aftermarket companies make heavy duty forks. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 25, 2021 Share Posted June 25, 2021 96 will be cable. 02 will be hydraulic. You probably want to use the 02 fork. You may or may not have to move the fork pivot ball location. I can't recall. GD 1 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 25, 2021 Share Posted June 25, 2021 Or, now is your chance to convert that trashy high maintenance hydraulic clutch to cable.... No failed master, slave cylinder, leakage, or annoying fluid changes and bleeding debacles. I've heard various reports on swapping between the two and the pivot ball locations like GD mentioned but haven't seen or tried enough of both to say for sure either what you'll encounter... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 26, 2021 Share Posted June 26, 2021 Yes - could swap to cable but IMO that's probably a bad idea from the standpoint of future maintenance. Could be anytime that Subaru OEM clutch cables for the 2001 and older Impreza go NLA in the parts system (and you certainly don't want aftermarket for that part based on EA experience). The hydraulics on the other hand are going to be supported for much longer and in my experience are rarely a problem. GD Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 27, 2021 Share Posted June 27, 2021 I can’t remember if the phase 1 gearbox has two pivot ball locations. The phase 2 boxes do for sure and the cable pivot is the one further away from the input shaft. I put two washers behind my pivot ball (on phase 2 cases) to get better leverage as the clutch fork would max out on the back of the hole it pokes out from. I think it had something to do with an aftermarket TOB that was a couple of mm thinner. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 27, 2021 Share Posted June 27, 2021 6 hours ago, el_freddo said: I put two washers behind my pivot ball (on phase 2 cases) to get better leverage as the clutch fork would max out on the back of the hole it pokes out from. I think it had something to do with an aftermarket TOB that was a couple of mm thinner. Cheers Bennie Nuts. How did you notice that? I feel like I’d just install it like any other clutch and move on. What was your first suspicion to check it out? Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 28, 2021 Share Posted June 28, 2021 19 hours ago, idosubaru said: Nuts. How did you notice that? I feel like I’d just install it like any other clutch and move on. What was your first suspicion to check it out? I didn’t like where the friction point was in the pedal travel, adjusted the cable then the pedal went hard before it hit the floor. That’s when I found out the fork maxing out on the case hole. Of course it meant the gearbox came out again. And the two washers were guess work. Which ever fork is used, it will dictate which pivot point to use since the two forks are different. Just sit the fork in there with the TOB and see where the fitment for the pivot lines up Cheers Bennie 1 Quote Link to comment Share on other sites More sharing options...
