suprunner Posted July 19, 2021 Share Posted July 19, 2021 (edited) I finally pulled the short block (SOA478H600R1) that I purchased a couple months ago out of the box and put onto a stand. Changed out the 7mm oil pump for a 9mm that I had (I don't think I'll need a 10mm as I'm a conservative driver, and this is just for a DD project). Looking at the pistons, they're labeled as 255 SH. Is this going to be a problem mounting with DOHC heads? When I was talking with a subaru parts tech over the phone I had specified that I wanted an EJ251 or EJ253 short block for '03-'05, and they had given me the part number. I had then talked with a different Parts Tech, and they confirmed that that part number was for what I had specified. Are the pistons the same? I thought the 255s were used with the AVL systems, and can't work with pre-AVLS. . Should I be looking for new pistons now? The current motor in my car is an EJ from a 2001 Impreza, with DOHC heads. I wanted to recreate the build as it is generally a nice and powerful (enough) motor. Also, I bought a brand new subaru water pump because I thought the stock one that came on the block was supposed to be forward facing.... What showed up is identical to the spare I bought. They are identical, right? Thanks all, Greg Edited July 19, 2021 by suprunner 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2021 Share Posted July 20, 2021 Negative. Those are not 255 pistons. GD Link to comment Share on other sites More sharing options...
suprunner Posted July 23, 2021 Author Share Posted July 23, 2021 Thank you! I'll start assembly then. Link to comment Share on other sites More sharing options...
