pcwizard2600 Posted July 12, 2004 Share Posted July 12, 2004 Sorry to post what is probably another redundant head gasket question, but here goes; I just purchased a 98 Legacy Outback Wagon with 116k on it. It is in very clean condition, has had the timing belt replaced recently, has a new clutch, and CarFax says there are no open recalls. I bought this from a used car dealer that specializes in pre owned subaru. (He has a good reputation) He said at this point there are no signs of head gasket problems, but based on all the posts, I'm sure that someday it will be needed. I'm a former auto technician (Master certified ASE, Chevrolet, & VW). Has anyone attempted to replace their own head gaskets, as opposed to taking it to a dealer? If so, what kind of job is it? Thanks.... Link to comment Share on other sites More sharing options...
cookie Posted July 12, 2004 Share Posted July 12, 2004 he did a very nice write up when he changed his. Frankly yours is about like doing two Hondas with two heads and two timing belts I believe. Link to comment Share on other sites More sharing options...
hohieu Posted July 13, 2004 Share Posted July 13, 2004 Yup, check out "theotherskip" Here is the link for his write-up; it's so good that it almost brought me to tears: http://mysite.verizon.net/vze730qe/...eplacement.html Link to comment Share on other sites More sharing options...
pcwizard2600 Posted July 13, 2004 Author Share Posted July 13, 2004 Thanks for the info and the link. Awesome write up on the procedure! Thanks again!! Link to comment Share on other sites More sharing options...
Ranger83 Posted July 13, 2004 Share Posted July 13, 2004 FWIW, I'm beginning to think that SOA is technically correct in saying they don't have a problem with head gaskets. The real culprit may actually be warped heads - which leads to head gasket failure. Link to comment Share on other sites More sharing options...
wrxsubaru Posted July 13, 2004 Share Posted July 13, 2004 FWIW, I'm beginning to think that SOA is technically correct in saying they don't have a problem with head gaskets. The real culprit may actually be warped heads - which leads to head gasket failure. But then why do all the head warp, i dought that every one that has replaced there engine has over heated it. Link to comment Share on other sites More sharing options...
theotherskip Posted July 13, 2004 Share Posted July 13, 2004 on my phase I engine, the heads were not out of spec. I had a machinest check. they didn't require any reconditioning, though i had new valve guides put in. iirc, 99obw's weren't warped either... Link to comment Share on other sites More sharing options...
