Norris Posted August 15, 2021 Share Posted August 15, 2021 Can anyone advise what model and year Subaru would of had a R160 diff with a 3.08 gear ratio? Link to comment Share on other sites More sharing options...
idosubaru Posted August 16, 2021 Share Posted August 16, 2021 (edited) I think you or I am confused - you said ‘diff’ and ‘gear ratio’. but diffs are generally referred to by their “final drive ratio”, not “gear ratio” so do you mean the final drive ratio of an R160 diff, or are you asking about (one of the) “gear ratios” (your words) of a transmission thats paired with an R160? If it’s trans gear ratio then I’m unfamiliar with those. If you mean the final drive ratio - the ratio of the diff itself, there are None in US nonturbo with that value (and I’m not aware of any common ones in US turbo either. Possible US final drive rear differential ratios: 3.55, 3.7, 3.9, 4.11, 4.44 If it exists - I’d guess it’s non-US market, or some outlier turbo STi JDM or something like that. Possibly a newer model but all of the I’ve seen are standard Subaru final drive ratios that have been around for awhile Edited August 16, 2021 by idosubaru Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 16, 2021 Share Posted August 16, 2021 quick google search seems to support Ido's conclusion. Seems to be a JDM item? Link to comment Share on other sites More sharing options...
el_freddo Posted August 16, 2021 Share Posted August 16, 2021 Not even a JDM option to my knowledge. And there’s no 3.08 gear ratio either. Typical first ratios are 3.454 or 3.545, second is 2.something or a high 1.something from memory. There are plenty of charts out there. I don’t even know if the Datsun crew have a 3.08 ratio. I know this ratio was available in the Holdens (Australia). Dunno about fords, not a Ford man. I hope this helps you out somehow. I’m looking forward to hear what you’re up to. Cheers Bennie Link to comment Share on other sites More sharing options...
Numbchux Posted August 16, 2021 Share Posted August 16, 2021 Take it easy guys. The question was clear, and relevant. And there are a lot more ratios available on the newer cars than that. Legacies and Outbacks with a turbo and a 5EAT have very tall diff ratios. Looks like 07-09 LGT 5EAT cars use that one in particular. Car-part.com lists that option for a Legacy 3.0 5EAT, but I couldn't reproduce it in Subaru's catalog. 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 16, 2021 Share Posted August 16, 2021 It probably exists but it's obscure and is probably used (as Numbchux alluded) along side the 5EAT. I know the 5EAT Legacy GT's were 3.27's so an even taller gear with the 3.0 / 5EAT combo seems reasonable. GD Link to comment Share on other sites More sharing options...
el_freddo Posted August 17, 2021 Share Posted August 17, 2021 Interesting and looks like a painful part to track down due to lack of numbers out there in comparison to the other ratios! Cheers Bennie Link to comment Share on other sites More sharing options...
Numbchux Posted August 17, 2021 Share Posted August 17, 2021 6 hours ago, el_freddo said: Interesting and looks like a painful part to track down due to lack of numbers out there in comparison to the other ratios! Cheers Bennie Meh, car-part shows 4 pages of results in the US. None close enough to me to drive to, but they can be shipped and they're cheap enough. Link to comment Share on other sites More sharing options...
Norris Posted February 17 Author Share Posted February 17 The differencial in question here that has the 3.08 gear ratio has the case OEM marked with XT code. Can anyone verify what model year it would have been out of? I need a side bearing retainer and need tonID the correct part. 1 Link to comment Share on other sites More sharing options...
idosubaru Posted February 17 Share Posted February 17 If it has the OEM code (or part number?) on it can you post the number or put the number into a Subaru online parts website and see what comes up? Link to comment Share on other sites More sharing options...
idosubaru Posted February 17 Share Posted February 17 12 hours ago, Norris said: The differencial in question here that has the 3.08 gear ratio How do you know it’s 3.08? Where did that number come from? Link to comment Share on other sites More sharing options...
Norris Posted April 11 Author Share Posted April 11 I rotated the diff and calculated the ratio. Its a 3.08. Another tech question. Does anyone have the steps or FSM instructions as how to set the Preload on a R160 diff with the Sundial or single bolt side bearing retainers style diff case? Link to comment Share on other sites More sharing options...
