Bergerb Posted August 24, 2021 Share Posted August 24, 2021 2001 Legacy after sitting in garage overnight Put into reverse and you get a loud clunk in the rear. After driving for 1/2-1mile there is the normal sound when putting into reverse. Only clunks after sitting overnight. Rear axles are fine, drive shaft only has 3/8” rotational play. I am stumped. Fluid is fine. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 24, 2021 Share Posted August 24, 2021 next morning, maybe a helper could 'pace' the car to determine if the noise is central (maybe diff mounts?) or on one side (brake or suspension?) do you set the parking brake? many parts could be suspect on a 21 year old car. Link to comment Share on other sites More sharing options...
forester2002s Posted August 25, 2021 Share Posted August 25, 2021 4 hours ago, 1 Lucky Texan said: do you set the parking brake? Good question! Could easily be that! Link to comment Share on other sites More sharing options...
Dinky26 Posted August 25, 2021 Share Posted August 25, 2021 Does the clunking go away after the mile? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 25, 2021 Share Posted August 25, 2021 Cold high idle results in higher transmission fluid pressure when engaging reverse. Rear diff to subframe bushings are probably shot. GD 1 Link to comment Share on other sites More sharing options...
lmdew Posted August 26, 2021 Share Posted August 26, 2021 Good call on the high cold idle! Link to comment Share on other sites More sharing options...
Bergerb Posted September 4, 2021 Author Share Posted September 4, 2021 Want to say thank you for replies. The rear diff bushings to sub frame are mushy. I’ll give update after replacing bushings. Link to comment Share on other sites More sharing options...
