brus brother Posted September 20, 2021 Share Posted September 20, 2021 2008 Outback. 130K miles. Rattling over bumps. I see that the lower control arm bushings are shot. Is there a way to distinguish between sound of those failed bushings and failed shock top mounts? I am not doing the repairs myself. Thinking I'd have them do the control arm bushings first which would not necessitate realignment and then if rattling persists, do the shocks? Mechanic is also suggesting the shock/spring loaded assembly instead of just the top mount (less labor to swap out the assembly than replace top mount?) If so, is Monroe a decent brand? Quote Link to comment Share on other sites More sharing options...
moosens Posted September 20, 2021 Share Posted September 20, 2021 They generally don’t give you quality parts in those kitted units. I’d be concerned that you’d be getting a cheaper top mount among other parts and that it’ll show mighty ugly in short order. Subafreak has done suspension for me in front of my eyes and to me it’s not a whole lot of extra labor to use the shop’s spring compressor and turn a wrench or two. Sidenote - have shopped at Perkins both online and over counter lately. The young fellow seems to have a better attitude these days and is rather courteous and helpful. Like been thrown in the deep end but he’s treading water well. The counter transaction was not a very healthy discount but at least he offered a little break. Good luck with it. Quote Link to comment Share on other sites More sharing options...
heartless Posted September 20, 2021 Share Posted September 20, 2021 honestly, would not put Monroes on a Subaru.. they are soft, almost mushy feeling KYB struts/shocks, and either OEM or KYB top mounts. takes a shop all of 5 minutes to squash the spring, pop the nut off the top, swap out parts, and reassemble one. We had the shop local to us do the other half's fronts for us.. in and out in about 15 minutes. 2 Quote Link to comment Share on other sites More sharing options...
lmdew Posted September 20, 2021 Share Posted September 20, 2021 1+ on KYB. Quote Link to comment Share on other sites More sharing options...
brus brother Posted September 20, 2021 Author Share Posted September 20, 2021 4 hours ago, moosens said: They generally don’t give you quality parts in those kitted units. I’d be concerned that you’d be getting a cheaper top mount among other parts and that it’ll show mighty ugly in short order. Subafreak has done suspension for me in front of my eyes and to me it’s not a whole lot of extra labor to use the shop’s spring compressor and turn a wrench or two. Sidenote - have shopped at Perkins both online and over counter lately. The young fellow seems to have a better attitude these days and is rather courteous and helpful. Like been thrown in the deep end but he’s treading water well. The counter transaction was not a very healthy discount but at least he offered a little break. Good luck with it. Perkins will allow you to order on line and pickup at counter to avoid shipping. Is the online price what you are calling the counter price? Quote Link to comment Share on other sites More sharing options...
moosens Posted September 21, 2021 Share Posted September 21, 2021 No , I had to stop in for a genuine over the counter , old fashioned transaction like buying a sandwich. I was rushing around and knew I’d be getting screwed a little on the price but threw in the towel. Just some bits. My online orders were significant, and I received their healthy discount whatever it is. I don’t have an actual number but it’s like John or Anthony were taking care of me. And yes KYB is really the way to go. You won’t like what the cheap top mounts look like after like 6 mos. Learned the hard way. Spend wisely my friend ! Ciao 1 Quote Link to comment Share on other sites More sharing options...
brus brother Posted October 2, 2021 Author Share Posted October 2, 2021 Changed lower control arm bushings (genuine Subaru) and front and rear sway bar links (Moog with zerk fittings) and the suspension is now as quiet as new. No need to start removing shocks to evaluate top mounts (necessitating realignment). Now to tackle the noisy exhaust. Used high temp furnace caulk a few years ago and might be time for another coat. 1 Quote Link to comment Share on other sites More sharing options...
heartless Posted October 2, 2021 Share Posted October 2, 2021 14 hours ago, brus brother said: No need to start removing shocks to evaluate top mounts (necessitating realignment). for the fronts at least, you do not need to remove them.. there is a rubber cover over the top - pop that off, shine a small flashlight in there, and you can tell if it is bad or not.. if you can see the ball bearings and/or rust, it needs replacing. (front has bearings for steering purposes) rears don't have the bearing so are less prone to problems, but the rubber does deteriorate over time. 1 Quote Link to comment Share on other sites More sharing options...
brus brother Posted October 3, 2021 Author Share Posted October 3, 2021 left rear shock boot/diaphragm/dust shield has dropped down. not sure how this happened or how the shock complex is assembled. is there a way of repositioning it or does this indicate some other deterioration? Quote Link to comment Share on other sites More sharing options...
heartless Posted October 3, 2021 Share Posted October 3, 2021 it is just a dust cover, and there is usually a foam rubber bumper kind of thing that holds it up.. that is probably a bit worn if it came down - the bumper thing just slides over the strut shaft, the dust boot slides over that... there is nothing else to hold it in place. would be more concerned about whether there is any oil showing on the shaft - even gas filled have a little oil in them. Quote Link to comment Share on other sites More sharing options...
