1995 Legacy 2.2 engine only with OEM ECU in Limp Mode
1995 2.2 Subaru Legacy engine has transplanted in a VW sand car, I have the 2.2 engine running with the stock ECU although with all the car gone but the engine it is in a limp mode at 3400 + RPM If there is anybody that knows how to circumvent all the limp modes. $$ the ECU is AB414  5602 / It has the gray plug. It idles good and runs good until limp mode. If anybody can help $$ will be appreciated very much.
Thank You Steve
there are 2 pairs of single wire diagnostic connectors on older Subarus... one pair is green, the other is black.. they are there for a 95, I know this for fact since I owned one.
they should be UNplugged for normal driving mode.. 95 was a voluntary OBDII setup, Subaru did not have to do that, but they did.. they also left the diagnostic connectors.
  • Like 1
